[PostGIS] #5862: Postgis topology, silently craating topo edge crosses edge , mixed face labeling in ring
trac at osgeo.org
Tue Apr 1 23:37:04 PDT 2025
labeling in ring
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone:
Component: topology | Version: master
Resolution: | Keywords: robustness
Comment (by Lars Aksel Opsahl):
Just as a comment here I had a input dataset which resulted in 33200 faces
and that was split in 133 working content based grid cell and in 10 of
those there was a topology error, some of the errors had an effect more
than one cell so distinct errors was
'("face without edges",80171,)'
'("face without edges",74918,)','("face has wrong mbr",72996,)'
'("face without edges",78662,)','("face has wrong mbr",74635,)'
'("face has wrong mbr",77591,)'
Then I did a new call with the exact same area and code but I change one
parameter at this to merge sliver areas that collapses if I buffer in with
one meter. This resulted in 33170 faces zero topology errors.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5862#comment:6>
