[SCM] PostGIS branch master updated. 3.5.0-262-gd5932073b
git at osgeo.org
git at osgeo.org
Thu Apr 10 11:53:29 PDT 2025
the project "PostGIS".
via d5932073b467aae0cca2e3f156f5538ceae5a0d5 (commit)
from 10b0e82e45aab19f78bd48194de1da02b3d64bae (commit)
revisions in full, below.
commit d5932073b467aae0cca2e3f156f5538ceae5a0d5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Apr 10 11:53:17 2025 -0700
Silence MacOS clang warnings
diff --git a/raster/rt_pg/rtpg_gdal.c b/raster/rt_pg/rtpg_gdal.c
index f65c7631e..441d40cfb 100644
--- a/raster/rt_pg/rtpg_gdal.c
+++ b/raster/rt_pg/rtpg_gdal.c
@@ -1094,7 +1094,7 @@ Datum RASTER_GDALWarp(PG_FUNCTION_ARGS)
#define gdalErrorTypesSize 17
-const char* const gdalErrorTypes[gdalErrorTypesSize] =
+static const char* const gdalErrorTypes[gdalErrorTypesSize] =
"None",
"AppDefined",
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index a28c2aca1..fadaa9611 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -266,7 +266,7 @@ rt_pg_options(const char* varname)
/* GDAL allowed config options for VSI filesystems */
-stringlist_t *vsi_option_stringlist = NULL;
+static stringlist_t *vsi_option_stringlist = NULL;
#if POSTGIS_GDAL_VERSION < 23
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 9a16ad17f..6d1f52770 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -52,7 +52,7 @@
PG_MODULE_MAGIC;
-LWT_BE_IFACE* be_iface;
+static LWT_BE_IFACE* be_iface;
* Private data we'll use for this backend
@@ -75,7 +75,7 @@ struct LWT_BE_DATA_T
int topoLoadFailMessageFlavor; /* 0:sql, 1:AddPoint */
-LWT_BE_DATA be_data;
+static LWT_BE_DATA be_data;
struct LWT_BE_TOPOLOGY_T
@@ -1521,7 +1521,7 @@ cb_getNodeWithinDistance2D(const LWT_BE_TOPOLOGY *topo,
else
lwpgwarning("liblwgeom-topo invoked 'getNodeWithinDistance2D' "
- "backend callback with limit=%ld and no fields",
+ "backend callback with limit=" UINT64_FORMAT " and no fields",
elems_requested);
appendStringInfo(sql, "*");
Summary of changes:
raster/rt_pg/rtpg_gdal.c | 2 +-
raster/rt_pg/rtpostgis.c | 2 +-
topology/postgis_topology.c | 6 +++---
3 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
