[PostGIS] #5879: regress failure on GDAL 3.11dev with st_transform
trac at osgeo.org
Thu Apr 10 19:26:02 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.4.5
Component: postgis | Version: 3.4.x
Keywords: |
Looks like latest/latest of GHA which follows GDAL main branch started
failing around mid march with:
This one is good
gdal hash of 6bbeccbef3 2025/03/16 is last good run we have:
https://github.com/postgis/postgis/actions/runs/13955097032/job/39064067252
This is the first we see of GHA latest latest failing -
https://github.com/postgis/postgis/actions/runs/14012537588/job/39263200786
GDAL: GDAL 3.11.0dev-8eb234d4d4, released 2025/03/21 is when we first
start seeing failures
raster/test/regress/loader/Basic .... ok in 197 ms
raster/test/regress/loader/Projected .... failed ( test: running
raster2pgsql output: /tmp/pgis_reg/loader.err)
BEGIN
CREATE TABLE
CREATE TABLE
psql:/tmp/pgis_reg/loader.out:4: ERROR: rt_raster_from_gdal_dataset:
Could not get data from GDAL raster
CONTEXT: SQL function "st_transform" statement 1
failed (Errors while running sql script ./raster/test/regress/loader
/Projected-post.sql: /tmp/pgis_reg/test_332_tmp)
ERROR: table "o_2_loadedrast" does not exist
... but cleanup sql failed! raster/test/regress/loader/BasicCopy .... ok
in 196 ms
raster/test/regress/loader/BasicFilename .... ok in 175 ms
raster/test/regress/loader/BasicOutDB .... ok in 203 ms
raster/test/regress/loader/Tiled10x10 .... ok in 181 ms
raster/test/regress/loader/Tiled10x10Copy .... ok in 175 ms
raster/test/regress/loader/Tiled8x8 .... ok in 190 ms
raster/test/regress/loader/TiledAuto .... ok in 150 ms
raster/test/regress/loader/TiledAutoSkipNoData .... ok in 121 ms
raster/test/regress/loader/TiledAutoCopyn .... ok in 118 ms
raster/test/regress/clean .. ok in 7 ms
before-uninstall-script ./regress/hooks/hook-before-uninstall.sql .. ok
uninstall .. ok (5530)
Run tests: 344
Failed: 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5879>
