[SCM] PostGIS branch master updated. 3.5.0-279-g8dde825bd
Mon Apr 21 20:47:46 PDT 2025
the project "PostGIS".
       via  8dde825bde110229e58568e65164d870d5f45a17 (commit)
      from  1d63e15610ce50df5c651d008062016d1bce1dd8 (commit)
revisions in full, below.
commit 8dde825bde110229e58568e65164d870d5f45a17
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Apr 22 02:08:22 2025 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 100.0% (5756 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index fc10b131b..f0e410e5b 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -8,7 +8,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
-"PO-Revision-Date: 2025-04-22 01:47+0000\n"
+"PO-Revision-Date: 2025-04-22 03:47+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/ja/>\n"
@@ -1680,7 +1680,7 @@ msgid ""
 "(token number \"13\"). (SADS elements \"ZIP CODE\" , \"PLUS 4\" ). This "
 "attribute is used for both the US Zip and the Canadian Postal Codes."
 msgstr ""
-"(トークン番号 \"13\") (SAD要素の\"ZIP CODE\" , \"PLUS 4\" ). 米国Zip (訳注: "
+"(トークン番号 \"13\") (SADS要素の\"ZIP CODE\" , \"PLUS 4\" ). 米国Zip (訳注: "
 "郵便番号)とカナダ郵便番号の両方で使われます。"
 #. Tag: para
Summary of changes:
 doc/po/ja/postgis-manual.po | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
