[SCM] PostGIS branch stable-3.3 updated. 3.3.7-23-g102b938f4
Tue Apr 22 11:31:43 PDT 2025
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  102b938f4425d3722546bf5b14b51360b43a2615 (commit)
      from  9393fc711c42e94ef4712ed1d42a8c470e17e6e8 (commit)
revisions in full, below.
commit 102b938f4425d3722546bf5b14b51360b43a2615
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 22 11:25:57 2025 -0700
    geometry_columns view fails with non-standard use of postgis functions in constraint definition, references #5829
diff --git a/NEWS b/NEWS
index a4833b070..5649c66a4 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Proj 4.9+ required.
 * Bug Fixes and Enhancements *
  - #5876, Fix ST_AddPoint with empty point argument (Paul Ramsey)
+ - #5829, geometry_columns with non-standard constraints (Paul Ramsey)
 PostGIS 3.3.8
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 5bf355a08..2bebee475 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6305,26 +6305,29 @@ CREATE OR REPLACE VIEW geometry_columns AS
 	 JOIN pg_type t ON a.atttypid = t.oid
 	 LEFT JOIN ( SELECT s.connamespace,
 			s.conrelid,
-			s.conkey, replace(split_part(s.consrc, ''''::text, 2), ')'::text, ''::text) As type
+			s.conkey,
+			(regexp_match(s.consrc, 'geometrytype\(\w+\)\s*=\s*(\w+)', 'i'))[1]::text AS type
 		   FROM (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
 				FROM pg_constraint) AS s
-		  WHERE s.consrc ~~* '%geometrytype(% = %'::text
+		  WHERE s.consrc ~* 'geometrytype(\w+)\s*=\s*\w+'::text
 ) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
 			s.conrelid,
-			s.conkey, replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text)::integer As ndims
+			s.conkey,
+			(regexp_match(s.consrc, 'ndims\(\w+\)\s*=\s*(\d+)', 'i'))[1]::integer AS ndims
-		  WHERE s.consrc ~~* '%ndims(% = %'::text
+		  WHERE s.consrc ~* 'ndims(\w+)\s*=\s*\d+'::text
 ) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
 			s.conrelid,
-			s.conkey, replace(replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text), '('::text, ''::text)::integer As srid
+			s.conkey,
+			(regexp_match(s.consrc, 'st_srid\(\w+\)\s*=\s*(\d+)', 'i'))[1]::integer As srid
-		  WHERE s.consrc ~~* '%srid(% = %'::text
+		  WHERE s.consrc ~* 'srid(\w+)\s*=\s*\d+'::text
 ) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
   WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
Summary of changes:
 NEWS                   |  1 +
 postgis/postgis.sql.in | 15 +++++++++------
 2 files changed, 10 insertions(+), 6 deletions(-)
hooks/post-receive
