[SCM] PostGIS branch master updated. 3.5.0-282-g9a37771d5
git at osgeo.org
git at osgeo.org
Tue Apr 22 11:37:28 PDT 2025
the project "PostGIS".
via 9a37771d50d045633f272dd687969684c9c272b8 (commit)
from 5fce1e18937683b49c282d15b64e35b6791eae07 (commit)
revisions in full, below.
commit 9a37771d50d045633f272dd687969684c9c272b8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Apr 22 11:33:17 2025 -0700
Remove constraint checking from geometry_columns view, now depends on typmod exclusively, reference #5829
diff --git a/NEWS b/NEWS
index 89f7b8d6a..25788c577 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ PostGIS 3.6.0
* Breaking Changes *
- #5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
+ - #5829, remove constraint checking from geometry_columns view (Paul Ramsey)
* Deprecated signatures *
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 7394698c2..ed39bbb0b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6389,37 +6389,13 @@ CREATE OR REPLACE VIEW geometry_columns AS
n.nspname AS f_table_schema,
c.relname AS f_table_name,
a.attname AS f_geometry_column,
- COALESCE(postgis_typmod_dims(a.atttypmod), sn.ndims, 2) AS coord_dimension,
- COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), sr.srid, 0) AS srid,
- replace(replace(COALESCE(NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::text), st.type, 'GEOMETRY'::text), 'ZM'::text, ''::text), 'Z'::text, ''::text)::character varying(30) AS type
+ COALESCE(postgis_typmod_dims(a.atttypmod), 2) AS coord_dimension,
+ COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), 0) AS srid,
+ replace(replace(COALESCE(NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::text), 'GEOMETRY'::text), 'ZM'::text, ''::text), 'Z'::text, ''::text)::character varying(30) AS type
FROM pg_class c
JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
JOIN pg_namespace n ON c.relnamespace = n.oid
JOIN pg_type t ON a.atttypid = t.oid
- LEFT JOIN ( SELECT s.connamespace,
- s.conrelid,
- s.conkey, replace(split_part(s.consrc, ''''::text, 2), ')'::text, ''::text) As type
- FROM (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
- FROM pg_constraint) AS s
- WHERE s.consrc ~~* '%geometrytype(% = %'::text
-) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
- s.conrelid,
- s.conkey, replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text)::integer As ndims
- WHERE s.consrc ~~* '%ndims(% = %'::text
-) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
- s.conrelid,
- s.conkey, replace(replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text), '('::text, ''::text)::integer As srid
- WHERE s.consrc ~~* '%srid(% = %'::text
-) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
AND NOT pg_is_other_temp_schema(c.relnamespace) AND has_table_privilege(c.oid, 'SELECT'::text);
Summary of changes:
NEWS | 1 +
postgis/postgis.sql.in | 30 +++---------------------------
2 files changed, 4 insertions(+), 27 deletions(-)
hooks/post-receive
