[PostGIS] #5829: SELECT geometry_columns returns unexpected error when there are constraints after SRID constraint.
PostGIS trac at osgeo.org
Tue Apr 22 11:38:20 PDT 2025
  Reporter:  nbvfgh    |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 3.6.0
 Component:  postgis   |    Version:  3.5.x
Resolution:  fixed     |   Keywords:
Changes (by pramsey):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 Master is updated to remove constraints as an input to geometry_columns,
 and stable branches updated to use regex approach to fix this bug.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5829#comment:7>
