[PostGIS] #5829: SELECT geometry_columns returns unexpected error when there are constraints after SRID constraint.
    trac at osgeo.org
    Tue Apr 22 12:26:09 PDT 2025
  Reporter:  nbvfgh    |      Owner:  pramsey
      Type:  defect    |     Status:  reopened
  Priority:  critical  |  Milestone:  PostGIS 3.6.0
 Component:  postgis   |    Version:  3.5.x
Resolution:            |   Keywords:
Changes (by robe):
 * resolution:  fixed =>
 * status:  closed => reopened
Comment:
 Replying to [comment:7 pramsey]:
 > Master is updated to remove constraints as an input to geometry_columns,
 and stable branches updated to use regex approach to fix this bug.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5829#comment:8>
