[PostGIS] #5829: SELECT geometry_columns returns unexpected error when there are constraints after SRID constraint.
trac at osgeo.org
Tue Apr 22 12:26:51 PDT 2025
Reporter: nbvfgh | Owner: pramsey
Type: defect | Status: reopened
Priority: critical | Milestone: PostGIS 3.6.0
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Failing non-standard conforming check -- put an E in front should fix it -
https://woodie.osgeo.org/repos/30/pipeline/2992/6
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5829#comment:9>
