[PostGIS] #5885: ST_Intersection with gridSize argument does not internally use ReducePrecision ?
trac at osgeo.org
Thu Apr 24 15:04:50 PDT 2025
ReducePrecision ?
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.13
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by mdavis):
Replying to [ticket:5885 strk]:
> I would expect the following queries to give the same result, instead
they don't:
It's hard to know whether the results are expected or not since the inputs
are not provided here. Can you make a full reproducer of this case?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5885#comment:3>
