[PostGIS] #5885: ST_Intersection with gridSize argument does not internally use ReducePrecision ?
trac at osgeo.org
Thu Apr 24 15:06:54 PDT 2025
ReducePrecision ?
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.13
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by mdavis):
Replying to [comment:2 strk]:
> It looks like the PostGIS side just calls GEOSIntersectionPrec without
any previous call to GEOSGeom_setPrecision, this was likely a mistake in
the original implementation.
This is by design. Reducing precision can be an expensive operation
(particularly on polygonal inputs). And it's not needed if the inputs are
already known to be precise. So it's intentionally left up to the user to
reduce the input precision if it's needed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5885#comment:4>
