[PostGIS] #5885: ST_Intersection with gridSize argument does not internally use ReducePrecision ?
trac at osgeo.org
Thu Apr 24 15:12:19 PDT 2025
ReducePrecision ?
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.13
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by mdavis):
Replying to [comment:2 strk]:
> I think we should enforce such precision, and in the future make
"precision" an information of the geometry objects themselves to speed
things up.
Easy to say, not so easy to design and implement in a clean, clear and
consistent way. I'll look forward to an RFC to indicate how this would
actually work.
Precision handling doesn't seem to be a big pain point for most PostGIS
users. It seems like it is mostly a problem in the Topology subsystem.
So perhaps it should be designed and built there first, and then can be
extended to other areas when it's proven out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5885#comment:5>
