[PostGIS] #5885: ST_Intersection with gridSize argument does not internally use ReducePrecision ?
trac at osgeo.org
Sun Apr 27 12:41:06 PDT 2025
ReducePrecision ?
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.13
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by strk):
> Can you make a full reproducer of this case?
#5862 has the inputs, here is the call that creates the input table:
CREATE TABLE t5862_inputs AS SELECT
'LINESTRING(
22.780107846871616 70.70515928614921,
22.779899976871615 70.7046262461492
)'::geometry e1,
'LINESTRING(
22.79217056687162 70.70247684614921,
22.779969266871618 70.70480392614921,
22.780038556871617 70.7049816061492,
22.796764346871615 70.7044482361492
::geometry e2;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5885#comment:6>
