[SCM] PostGIS branch master updated. 3.6.0beta1-22-g46f885fef
git at osgeo.org
git at osgeo.org
Mon Aug 11 17:47:47 PDT 2025
the project "PostGIS".
via 46f885fef3e0e1ac01621c12fdce15bab71a5433 (commit)
from 4861b3682f855ef1c1782c1585e0785e2a79ded7 (commit)
revisions in full, below.
commit 46f885fef3e0e1ac01621c12fdce15bab71a5433
Author: Denys Kovshun <deniskovshun at gmail.com>
Date: Mon Aug 11 23:32:17 2025 +0000
Translated PostGIS Manual using Weblate (Ukrainian)
Currently translated at 5.8% (344 of 5848 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/uk/
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 5a7c4e57b..6e107a76e 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -5,7 +5,7 @@ msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-07-20 04:11+0000\n"
-"PO-Revision-Date: 2025-08-11 18:47+0000\n"
+"PO-Revision-Date: 2025-08-12 00:47+0000\n"
"Last-Translator: Denys Kovshun <deniskovshun at gmail.com>\n"
"Language-Team: Ukrainian <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/uk/>\n"
@@ -3359,13 +3359,13 @@ msgstr ""
"включена в завантаження скрипту вашої країни, виконайте наступні дії:"
#. Tag: para
-#, no-c-format
+#, fuzzy, no-c-format
msgid ""
"If you were running <varname>tiger_2010</varname> version and you want to "
"reload as state with newer tiger data, you'll need to for the very first "
"load generate and run drop statements <xref "
"linkend=\"Drop_Nation_Tables_Generate_Script\"/> before you run this script."
-msgstr ""
+msgstr "Якщо ви введете геометрії з різними SRID, ви отримаєте помилку:"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/uk/postgis-manual.po | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
