[SCM] PostGIS branch master updated. 3.5.0-441-g0aa8924b9
git at osgeo.org
git at osgeo.org
Wed Jul 9 19:13:03 PDT 2025
the project "PostGIS".
via 0aa8924b94a4d2de477e0fa0f9b0f47ee98218ff (commit)
from d049349da81b6f18ceb318260bc60014cb76abbc (commit)
revisions in full, below.
commit 0aa8924b94a4d2de477e0fa0f9b0f47ee98218ff
Author: Ayo Adesugba <ayoadesugba at gmail.com>
Date: Tue Jul 1 00:16:45 2025 -0400
Closes #3373 support for topology upgrading domains
Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/255
References https://git.osgeo.org/gitea/postgis/postgis/pulls/255
Closes https://github.com/postgis/postgis/pull/821
References https://github.com/postgis/postgis/pull/821
Minor change to combine the create domain with all constraints for same available version.
Fix the create_upgrade script to handle domains
Fixed the create domain handler
Add to NEWS and credits
diff --git a/NEWS b/NEWS
index 7952cfacb..583a31c6b 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,7 @@ Daniel Nylander (Swedish Team)
- #5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
- #5829, remove constraint checking from geometry_columns view (Paul Ramsey)
+ - #3373, GT-255 [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)
* Deprecated signatures *
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 91034b489..98c4af7b5 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -231,6 +231,7 @@
<member>Antoine Bajolet</member>
<member>Arthur Lesuisse</member>
<member>Artur Zakirov</member>
+ <member>Ayo Adesugba</member>
<member>Barbara Phillipot</member>
<member>Ben Jubb</member>
<member>Bernhard Reiter</member>
@@ -401,6 +402,7 @@
<listitem><simpara><link xlink:href="http://www.uster.ch">Stadt Uster</link></simpara></listitem>
<listitem><simpara><link xlink:href="https://www.ucdavis.edu">UC Davis Center for Vectorborne Diseases</link></simpara></listitem>
<listitem><simpara><link xlink:href="https://www.ulaval.ca">Université Laval</link></simpara></listitem>
+ <listitem><simpara><link xlink:href="https://www.census.gov">U.S. Census Bureau</link></simpara></listitem>
<listitem><simpara><link xlink:href="https://hiu.state.gov">U.S. Department of State (HIU)</link></simpara></listitem>
<listitem><simpara><link xlink:href="https://www.zonarsystems.com">Zonar Systems</link></simpara></listitem>
</itemizedlist>
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 91d603ea6..64997937a 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -350,45 +350,40 @@ CREATE TYPE topology.TopoGeometry AS (
-- element_type will be the child layer identifier and
-- element_id will be composing TopoGeometry identifier
+-- Availability: 1.1.0
CREATE DOMAIN topology.TopoElement AS integer[]
+ -- Availability: 1.1.0
CONSTRAINT DIMENSIONS CHECK (
array_upper(VALUE, 2) IS NULL
AND array_upper(VALUE, 1) = 2
-ALTER DOMAIN topology.TopoElement ADD
- CONSTRAINT lower_dimension CHECK (
- array_lower(VALUE, 1) = 1
-ALTER DOMAIN topology.TopoElement DROP CONSTRAINT
- IF EXISTS
- type_range;
- CONSTRAINT type_range CHECK (
+ CONSTRAINT type_range CHECK (
VALUE[2] > 0
+ -- Availability: 2.0.0
+ CONSTRAINT lower_dimension CHECK (
+ array_lower(VALUE, 1) = 1
-- TopoElementArray domain
--- Changed: 3.1.0 - get rid of IS NOT NULL check
CREATE DOMAIN topology.TopoElementArray AS integer[][]
+ -- Changed: 3.1.0 - get rid of IS NOT NULL check
array_upper(VALUE, 2) = 2
AND array_upper(VALUE, 3) IS NULL
--- Changed: 3.1.0
-ALTER DOMAIN topology.TopoElementArray DROP CONSTRAINT
- IF EXISTS
- DIMENSIONS;
-ALTER DOMAIN topology.TopoElementArray ADD
+ -- Availability: 3.1.0
--{ RelationTrigger()
-- Relation integrity trigger
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
old mode 100755
new mode 100644
index 79af6fa8b..b4f51985c
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -79,6 +79,14 @@ sub parse_missing
return join(',', at missing);
+sub remove_line_break
+ my $line = shift;
+ $line =~ s/\s+/ /g; # Replace all whitespace (including newlines, tabs) with single spaces
+ $line =~ s/^\s+|\s+$//g; # Trim leading and trailing whitespace
+ return $line;
# Commandline argument handling
@@ -187,6 +195,220 @@ while(<INPUT>)
print if (/^drop function /i);
print if (/^drop aggregate /i);
+ if (/^create domain\s+([^.]+)\.([^\s]+)\s+as\s+([^;]+)/i) {
+ my $schema = lc($1);
+ my $name = lc($2);
+ my $type = lc($3);
+ $type = remove_line_break($type); # Normalize whitespace using helper function
+ my $def .= $_;
+ my $subcomment = '';
+ my @constraints; # [type, definition, last_updated, comment]
+ my $type_changed = 0;
+ my $all_constraints_created_together = 1;
+ print "\n\n-- Domain: $schema.$name($type)\n";
+ my @replaced_array = parse_replaces($comment);
+ my $domain_last_updated = parse_last_updated($comment);
+ if ( !$domain_last_updated )
+ die "ERROR: no last updated info for domain '${schema}.${name}($type)'\n";
+ my $missing = parse_missing($comment);
+ unless (/;\s*$/) {
+ while(my $line = <INPUT>) {
+ if ($line =~ /^\s*\-\-/) {
+ $subcomment .= remove_line_break($line);
+ next;
+ # Find NOT NULL or NULL constraint in domain definition ignore ;
+ if ($line =~ /^\s*(NOT\s+NULL|NULL)\s*;?\s*$/i) {
+ my $ctype = uc($1);
+ my $last_updated = parse_last_updated($subcomment);
+ my $missing = parse_missing($subcomment);
+ if ( $last_updated ) {
+ push @constraints, [$ctype, '', $ctype, $last_updated, $missing, $subcomment];
+ } else {
+ die "ERROR: no last updated info for constraint '${ctype}' in ${schema}.${name}($type)\n";
+ $subcomment = '';
+ if ($line =~ /;\s*$/) {
+ $def .= "$ctype;\n";
+ last;
+ } else {
+ $def .= "$ctype\n";
+ next;
+ if ($line =~ /CONSTRAINT\s+(\w+)\s+CHECK/i) {
+ my $constraint_name = $1;
+ my $constraint = $line;
+ my $open_parens = ($constraint =~ tr/(//);
+ my $close_parens = ($constraint =~ tr/)//);
+ my $found_semicolon = 0;
+ while ($open_parens == 0 || $open_parens > $close_parens) {
+ my $nextline = <INPUT>;
+ last unless defined $nextline;
+ if ($nextline =~ /;\s*$/) {
+ $found_semicolon = 1;
+ $nextline =~ s/;\s*$//;
+ $constraint .= $nextline;
+ $open_parens += ($nextline =~ tr/(//);
+ $close_parens += ($nextline =~ tr/)//);
+ # Make a single line of the constraint
+ $constraint = remove_line_break($constraint);
+ push @constraints, ['CHECK', $constraint_name, $constraint, $last_updated, $missing, $subcomment];
+ } else {
+ die "ERROR: no last updated info for constraint '${constraint_name}' in ${schema}.${name}($type)\n";
+ $subcomment = ''; # Reset subcomment after using it
+ if ($found_semicolon) {
+ $def .= "$constraint;\n";
+ last;
+ } else {
+ $def .= "$constraint\n";
+ next;
+ last if $line =~ /;\s*$/; # End of domain definition
+ foreach my $c (@constraints) {
+ my ($ctype, $cname, $cdef, $last_updated, $missing, $comment) = @$c;
+ if ($domain_last_updated != $last_updated) {
+ $all_constraints_created_together = 0;
+ if (@replaced_array) {
+ foreach my $replaced(@replaced_array)
+ my ($rname, $rargs, $ver) = @$replaced;
+ $rname = lc($rname); # lowercase the name
+ my $old_type = lc($rargs);
+ my $new_type = lc($type);
+ if ($old_type ne $new_type)
+ $type_changed = 1;
+ print <<"EOF";
+-- ${schema}.${name}($old_type) -- LastUpdated: ${domain_last_updated}
+-- Updated Domain ${schema}.${name}($new_type)
+-- We cannot drop the old domain, so we modify it
+DO LANGUAGE 'plpgsql'
+\$postgis_domain_upgrade\$
+BEGIN
+IF $ver > version_from_num
+EOF
+ print "OR version_from_num IN ( ${missing} )" if ($missing);
+ print <<"EOF";
+ FROM _postgis_upgrade_info()
+THEN
+ IF EXISTS (SELECT 1 FROM pg_catalog.pg_type AS t
+ WHERE typnamespace::regnamespace::text = 'topology'
+ AND typname = '$name' AND typbasetype::regtype::text = '$old_type')
+ THEN
+ UPDATE pg_catalog.pg_type SET typbasetype = '$new_type'::regtype::oid
+ AND typname::text = '$name' AND typbasetype::regtype::text = '$old_type';
+EOF
+ print <<"EOF";
+ EXECUTE \$postgis_domain_upgrade_parsed_def\$ ALTER DOMAIN ${schema}.${name} DROP CONSTRAINT IF EXISTS $cname \$postgis_domain_upgrade_parsed_def\$;
+ EXECUTE \$postgis_domain_upgrade_parsed_def\$ ALTER DOMAIN ${schema}.${name} ADD $cdef \$postgis_domain_upgrade_parsed_def\$;
+EOF
+ print <<"EOF";
+ RAISE DEBUG 'Upgraded % from % to %', '$name', '$old_type', '$new_type';
+ END IF;
+END IF;
+END
+\$postgis_domain_upgrade\$;\n
+EOF
+ } elsif ($all_constraints_created_together) {
+ print <<"EOF";
+BEGIN
+IF $domain_last_updated > version_from_num
+EOF
+ print "OR version_from_num IN ( ${missing} )\n" if ($missing);
+ print <<"EOF";
+FROM _postgis_upgrade_info()
+THEN
+ EXECUTE \$postgis_domain_upgrade_parsed_def\$ $def \$postgis_domain_upgrade_parsed_def\$;
+END IF;
+END
+EOF
+ } else {
+ print <<"EOF";
+BEGIN
+IF $last_updated > version_from_num
+EOF
+ print <<"EOF";
+THEN
+END IF;
+END
+EOF
+ print "\n";
+ if (/^alter\s+domain\s+([^.]+)\.([^\s]+)\s/ims)
+ # This is a domain alteration, which we do not support in upgrade scripts
+ # since we cannot drop and recreate domains.
+ # We will just die with an error message.
+ my $schema = $1;
+ my $name = remove_line_break(lc($2));
+ #print "Altering domain $schema.$name is not supported in upgrade scripts.\n";
+ # Die if we find an ALTER DOMAIN command
+ die "ERROR: ALTER DOMAIN command found for domain '${name}'\n";
if (/^create or replace function/i)
my $def .= $_;
@@ -784,3 +1006,4 @@ END
LANGUAGE 'plpgsql';
Summary of changes:
NEWS | 1 +
doc/introduction.xml | 2 +
topology/topology.sql.in | 37 ++++----
utils/create_upgrade.pl | 223 +++++++++++++++++++++++++++++++++++++++++++++++
4 files changed, 242 insertions(+), 21 deletions(-)
mode change 100755 => 100644 utils/create_upgrade.pl
hooks/post-receive
