[PostGIS] #5923: CG_ExtrudeStraightSkeleton crashes with polygon empty
PostGIS trac at osgeo.org
Thu Jun 5 18:55:09 PDT 2025
 Reporter:  robe     |      Owner:  Loïc Bartoletti
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS SFCGAL
Component:  sfcgal   |    Version:  3.5.x
 Keywords:           |
 SELECT CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326),
 20.1, 20.1)
 I tested on my install -
 POSTGIS="3.6.0dev 3.5.0-373-g51b525ac5" [EXTENSION] PGSQL="180" GEOS="3.14
 .0dev-CAPI-1.20.0" SFCGAL="SFCGAL 2.1.0, CGAL 6.0.1, BOOST 1.88.0"
 I also turned on garden testing on GHA and it crashes there, I think that
 is more or less 2.1.0 or master branch
 https://github.com/robe2/postgis/actions/runs/15480665967/job/43585783915#step:4:1451
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5923>
