[PostGIS] #5923: CG_ExtrudeStraightSkeleton crashes with polygon empty
trac at osgeo.org
Thu Jun 5 19:00:27 PDT 2025
Reporter: robe | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.4
Component: sfcgal | Version: 3.5.x
Resolution: | Keywords:
Changes (by robe):
* milestone: PostGIS SFCGAL => PostGIS 3.5.4
Old description:
> SELECT CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326),
> 20.1, 20.1)
> I tested on my install -
> POSTGIS="3.6.0dev 3.5.0-373-g51b525ac5" [EXTENSION] PGSQL="180"
> GEOS="3.14.0dev-CAPI-1.20.0" SFCGAL="SFCGAL 2.1.0, CGAL 6.0.1, BOOST
> 1.88.0"
> I also turned on garden testing on GHA and it crashes there, I think that
> is more or less 2.1.0 or master branch
> https://github.com/robe2/postgis/actions/runs/15480665967/job/43585783915#step:4:1451
New description:
20.1, 20.1)
POSTGIS="3.6.0dev 3.5.0-373-g51b525ac5" [EXTENSION] PGSQL="180" GEOS="3.14
.0dev-CAPI-1.20.0" SFCGAL="SFCGAL 2.1.0, CGAL 6.0.1, BOOST 1.88.0"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5923#comment:1>
