[SCM] PostGIS branch master updated. 3.5.0-388-g055a90ba6
git at osgeo.org
git at osgeo.org
Mon Jun 9 07:48:30 PDT 2025
the project "PostGIS".
via 055a90ba66cd95ac9c7870aa936c461507e1e435 (commit)
from 6c8c02282ce6e5fe2530ac15ad1deb63dc5ea587 (commit)
revisions in full, below.
commit 055a90ba66cd95ac9c7870aa936c461507e1e435
Author: Daniel Nylander <daniel at danielnylander.se>
Date: Mon Jun 9 13:43:04 2025 +0000
Translated PostGIS Manual using Weblate (Swedish)
Currently translated at 100.0% (5807 of 5807 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/sv/
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index d9c0f6aef..d462aa1ee 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -5,7 +5,7 @@ msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
-"PO-Revision-Date: 2025-06-09 12:47+0000\n"
+"PO-Revision-Date: 2025-06-09 14:47+0000\n"
"Last-Translator: Daniel Nylander <daniel at danielnylander.se>\n"
"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/sv/>\n"
@@ -1007,9 +1007,9 @@ msgid ""
"<link xlink:href=\"http://sourceforge.net/p/pagc/code/360/tree/branches/sew-"
"refactor/postgresql\">PAGC PostgreSQL Address Standardizer</link>)."
msgstr ""
-"Detta är en gaffel av <link xlink:href=\"http://www.pagcgeo.org/docs/html/"
-"pagc-11.html\">PAGC-standardiseraren</link> (originalkod för denna del var "
-"<link xlink:href=\"http://sourceforge.net/p/pagc/code/360/tree/branches/"
+"Detta är en förgrening av <link xlink:href=\"http://www.pagcgeo.org/docs/"
+"html/pagc-11.html\">PAGC-standardiseraren</link> (originalkod för denna del "
+"var <link xlink:href=\"http://sourceforge.net/p/pagc/code/360/tree/branches/"
"sew-refactor/postgresql\">PAGC PostgreSQL Address Standardizer</link>)."
#. Tag: para
@@ -1129,7 +1129,7 @@ msgstr ""
#. Tag: title
#, no-c-format
msgid "Address Standardizer Types"
-msgstr "Typer av adressstandardiserare"
+msgstr "Typer av adresstandardiserare"
#. Tag: para
#, no-c-format
@@ -1313,7 +1313,7 @@ msgstr ""
#. Tag: title
#, no-c-format
msgid "Address Standardizer Tables"
-msgstr "Tabeller för adressstandardisering"
+msgstr "Tabeller för adresstandardisering"
#. Tag: para
#, no-c-format
@@ -1330,7 +1330,7 @@ msgstr ""
"tabeller inte behöver namnges på samma sätt som det som hänvisas till här. "
"Du kan ha olika lex-, gaz-, regeltabeller för varje land till exempel eller "
"för din anpassade geokodare. Namnen på dessa tabeller skickas in i "
-"adressstandardiseringsfunktionerna."
+"adresstandardiseringsfunktionerna."
#. Tag: para
#, no-c-format
@@ -1950,7 +1950,7 @@ msgstr ""
#. Tag: title
#, no-c-format
msgid "Address Standardizer Functions"
-msgstr "Funktioner för adressstandardisering"
+msgstr "Funktioner för adresstandardisering"
#. Tag: refpurpose
#, no-c-format
@@ -1970,7 +1970,7 @@ msgid ""
"<xref linkend=\"gaztab\"/>, and <xref linkend=\"rulestab\"/> table names and "
"an address."
msgstr ""
-"Detta är en funktion för felsökning av regler för adressstandardisering och "
+"Detta är en funktion för felsökning av regler för adresstandardisering och "
"lex/gaz-mappningar. Den returnerar en json-formaterad text som innehåller "
"matchningsregler, mappning av tokens och bästa standardiserade adress <xref "
"linkend=\"stdaddr\"/> form av en inmatningsadress som använder <xref linkend="
@@ -2511,7 +2511,7 @@ msgid ""
"number the worse the result."
msgstr ""
"Målet med detta projekt är att bygga en fullt fungerande geokodare som kan "
-"bearbeta en godtycklig adresssträng i USA och med hjälp av normaliserade "
+"bearbeta en godtycklig adressträng i USA och med hjälp av normaliserade "
"TIGER-folkräkningsdata producera en punktgeometri och ett betyg som "
"återspeglar platsen för den givna adressen och sannolikheten för platsen. Ju "
"högre betygssiffra desto sämre resultat."
@@ -9241,7 +9241,7 @@ msgstr ""
#. Tag: title
#, no-c-format
msgid "Installing and Using the address standardizer"
-msgstr "Installera och använda adressstandardiseraren"
+msgstr "Installera och använda adresstandardiseraren"
#. Tag: para
#, no-c-format
@@ -9626,7 +9626,7 @@ msgstr ""
"prepping före geokodning. Normaliseraren är långt ifrån perfekt och att "
"försöka lappa dess ofullkomlighet tar en enorm mängd resurser. Därför har vi "
"integrerat med ett annat projekt som har en mycket bättre "
-"adressstandardiseringsmotor. För att använda denna nya address_standardizer "
+"adresstandardiseringsmotor. För att använda denna nya address_standardizer "
"kompilerar du tillägget enligt beskrivningen i <xref linkend="
"\"installing_pagc_address_standardizer\"/> och installerar det som ett "
"tillägg i din databas."
Summary of changes:
doc/po/sv/postgis-manual.po | 24 ++++++++++++------------
1 file changed, 12 insertions(+), 12 deletions(-)
hooks/post-receive
