[PostGIS] #6062: More error XX000: SQL/MM Spatial exception - geometry
trac at osgeo.org
Wed Apr 1 00:46:08 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.2
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
I have installed this version on a new server and am currently running it
on other problem areas where we miss results.
When running CreateTopology with zero precision, I encountered the
following error:
XX000: Side-location conflict: new edge starts in face 63 and ends in face
6876
However, when I switch back to a precision of 1e‑07, it works correctly
for that area. At the moment, the main focus is to get the correct
results. I will do more comparative testing of these two versions later
and report back.
Regarding the comment about running with zero tolerance: one drawback is
that it leaves a big cleanup work for the post jobs. This typically
involves removing a significant number of extra edges, which is
time‑consuming.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6062#comment:18>
