[SCM] PostGIS branch master updated. 3.6.0rc2-426-gae9559672
Wed Apr 1 12:04:56 PDT 2026
the project "PostGIS".
       via  ae9559672d2e329cee44bd697bac8411b94af13f (commit)
       via  765787f0976adfe7ae83cbf4dabf7cb5188288b9 (commit)
       via  515152e7bf193e6d75831e3794d9d0610d9c7dae (commit)
      from  53280a4f683f696e8086609fd681d380519487b9 (commit)
revisions in full, below.
commit ae9559672d2e329cee44bd697bac8411b94af13f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Apr 1 12:04:51 2026 -0700
    Add news entry for ST_CoverageEdges
diff --git a/NEWS b/NEWS
index be561f67a..a0a1146c4 100644
--- a/NEWS
+++ b/NEWS
@@ -17,6 +17,8 @@ This version requires GEOS 3.10 or higher
 * New Features *
+ - ST_CoverageEdges, returns MultiLinestring of distinct shared edges in
+          polygonal coverage (Paul Ramsey)
  - ST_MinimumSpanningTree, window function to calculate MST (Paul Ramsey)
  - #5993, [topology] Add max_edges parameter to TopoGeo_AddLinestring
           (Sandro Santilli)
commit 765787f0976adfe7ae83cbf4dabf7cb5188288b9
Date:   Wed Apr 1 12:03:17 2026 -0700
    Implement ST_CoverageEdges using GEOSCoverageEdges from GEOS 3.15
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index ccd8b868a..bad27160a 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -357,6 +357,76 @@ SELECT id, ST_AsText(ST_CoverageSimplify(geom, 30) OVER ())
   </refentry>
+  <refentry xml:id="ST_CoverageEdges">
+    <refnamediv>
+      <refname>ST_CoverageEdges</refname>
+      <refpurpose>Computes the unique edges of a polygonal coverage.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+      <funcsynopsis>
+        <funcprototype>
+          <funcdef>geometry <function>ST_CoverageEdges</function></funcdef>
+          <paramdef><type>geometry </type>
+            <parameter>geom</parameter></paramdef>
+          <paramdef choice="opt"><type>integer </type>
+            <parameter>edgetype = 0</parameter></paramdef>
+        </funcprototype>
+        <funcprototype>
+          <paramdef><type>geometry[] </type>
+            <parameter>geoms</parameter></paramdef>
+        </funcprototype>
+      </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+      <title>Description</title>
+      <para>Returns a MultiLineString representing the unique edges of a polygonal coverage.
+      A polygonal coverage is a set of non-overlapping polygons where adjacent polygons have matching vertices along shared edges.
+      </para>
+      <para>The <parameter>edgetype</parameter> parameter can be used to select which edges are returned:
+        <itemizedlist>
+          <listitem><para><emphasis role="bold">0 (ALL)</emphasis> - all unique edges (default)</para></listitem>
+          <listitem><para><emphasis role="bold">1 (EXTERIOR)</emphasis> - only exterior edges (non-shared)</para></listitem>
+          <listitem><para><emphasis role="bold">2 (INTERIOR)</emphasis> - only interior edges (shared)</para></listitem>
+        </itemizedlist>
+      </para>
+      <para role="availability" conformance="3.7.0">Availability: 3.7.0</para>
+      <para role="geos_requirement" conformance="3.15.0">Requires GEOS >= 3.15.0</para>
+    </refsection>
+    <refsection>
+      <title>Examples</title>
+      <programlisting>
+-- Get all unique edges of a coverage
+SELECT ST_AsText(ST_CoverageEdges(ST_GeomFromText('GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), POLYGON((10 0, 20 0, 20 10, 10 10, 10 0)))')));
+MULTILINESTRING((0 0, 10 0), (10 0, 20 0), (20 0, 20 10), (20 10, 10 10), (10 10, 0 10), (0 10, 0 0), (10 0, 10 10))
+-- Get only interior (shared) edges
+SELECT ST_AsText(ST_CoverageEdges(ST_GeomFromText('GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), POLYGON((10 0, 20 0, 20 10, 10 10, 10 0)))'), 2));
+MULTILINESTRING((10 0, 10 10))
+      </programlisting>
+    </refsection>
+    <refsection>
+      <title>See Also</title>
+      <para>
+        <xref linkend="ST_CoverageInvalidEdges"/>,
+        <xref linkend="ST_CoverageSimplify"/>,
+        <xref linkend="ST_CoverageUnion"/>
+      </para>
+    </refsection>
+  </refentry>
   <refentry xml:id="ST_CoverageUnion">
     <refnamediv>
       <refname>ST_CoverageUnion</refname>
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index 2870527fe..be55bdaba 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -982,6 +982,7 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS)
 	GEOSGeometry *geos = NULL;
 	GEOSGeometry *geos_result = NULL;
 	uint32 ngeoms = 0;
+	int srid = SRID_UNKNOWN;
 	ArrayType *array = PG_GETARG_ARRAYTYPE_P(0);
 	uint32 nelems = ArrayGetNItems(ARR_NDIM(array), ARR_DIMS(array));
@@ -1006,6 +1007,10 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS)
 		gser = (GSERIALIZED *)DatumGetPointer(value);
 		if (gserialized_is_empty(gser)) continue;
+		/* Get SRID from first non-null element */
+		if (srid == SRID_UNKNOWN)
+			srid = gserialized_get_srid(gser);
 		/* Omit unconvertible */
 		geos = POSTGIS2GEOS(gser);
 		if (!geos) continue;
@@ -1015,7 +1020,9 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS)
 	array_free_iterator(iterator);
 	if (ngeoms == 0)
 		PG_RETURN_NULL();
 	geos = GEOSGeom_createCollection(
 		GEOS_GEOMETRYCOLLECTION,
@@ -1027,6 +1034,8 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS)
 		HANDLE_GEOS_ERROR("Geometry could not be converted");
+	GEOSSetSRID(geos, srid);
 	geos_result = GEOSCoverageUnion(geos);
 	GEOSGeom_destroy(geos);
 	if (!geos_result)
@@ -1038,6 +1047,139 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(result);
+ * ST_CoverageEdges(geometry, edgetype)
+ * ST_CoverageEdges(geometry[], edgetype)
+Datum ST_CoverageEdges(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_CoverageEdges);
+#if POSTGIS_GEOS_VERSION < 31500
+	lwpgerror("The GEOS version this PostGIS binary "
+	          "was compiled against (%d) doesn't support "
+	          "'ST_CoverageEdges' function (3.15.0+ required)",
+	          POSTGIS_GEOS_VERSION);
+	PG_RETURN_NULL();
+#else
+	GSERIALIZED *result = NULL;
+	GSERIALIZED *gser = PG_GETARG_GSERIALIZED_P(0);
+	int edgetype = PG_GETARG_INT32(1);
+	GEOSGeometry *geos = NULL;
+	GEOSGeometry *geos_result = NULL;
+	if (gserialized_is_empty(gser))
+		PG_RETURN_NULL();
+	initGEOS(lwpgnotice, lwgeom_geos_error);
+	geos = POSTGIS2GEOS(gser);
+	if (!geos)
+		HANDLE_GEOS_ERROR("Geometry could not be converted");
+	geos_result = GEOSCoverageEdges(geos, edgetype);
+	GEOSGeom_destroy(geos);
+	if (!geos_result)
+		HANDLE_GEOS_ERROR("Error computing coverage edges");
+	result = GEOS2POSTGIS(geos_result, LW_FALSE);
+	GEOSGeom_destroy(geos_result);
+	PG_RETURN_POINTER(result);
+#endif
+Datum ST_CoverageEdges_array(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_CoverageEdges_array);
+	PG_RETURN_NULL();
+#else
+	Datum value;
+	bool isnull;
+	GEOSGeometry **geoms = NULL;
+	uint32 ngeoms = 0;
+	ArrayType *array = PG_GETARG_ARRAYTYPE_P(0);
+	uint32 nelems = ArrayGetNItems(ARR_NDIM(array), ARR_DIMS(array));
+	ArrayIterator iterator = array_create_iterator(array, 0, NULL);
+	/* Return null on 0-elements input array */
+	if (nelems == 0)
+		PG_RETURN_NULL();
+	/* Convert all geometries into GEOSGeometry array */
+	geoms = palloc(sizeof(GEOSGeometry *) * nelems);
+	while (array_iterate(iterator, &value, &isnull))
+		GSERIALIZED *gser;
+		/* Omit nulls */
+		if (isnull) continue;
+		/* Omit empty */
+		gser = (GSERIALIZED *)DatumGetPointer(value);
+		if (gserialized_is_empty(gser)) continue;
+		/* Omit unconvertible */
+		if (!geos) continue;
+		geoms[ngeoms++] = geos;
+	array_free_iterator(iterator);
+	if (ngeoms == 0)
+		PG_RETURN_NULL();
+	geos = GEOSGeom_createCollection(
+		GEOS_GEOMETRYCOLLECTION,
+		geoms, ngeoms);
+	if (!geos)
+		coverage_destroy_geoms(geoms, ngeoms);
+	if (!geos_result)
+#endif
 extern Datum ST_MinimumSpanningTree(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(ST_MinimumSpanningTree);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 41a7ee22a..649ed3fc5 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4498,6 +4498,20 @@ CREATE OR REPLACE FUNCTION ST_CoverageClean (geom geometry, gapMaximumWidth floa
 	LANGUAGE 'c' IMMUTABLE STRICT WINDOW PARALLEL SAFE
 	_COST_HIGH;
+-- Availability: 3.7.0
+CREATE OR REPLACE FUNCTION ST_CoverageEdges (geoms geometry[], edgetype integer default 0)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_CoverageEdges_array'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_HIGH;
+CREATE OR REPLACE FUNCTION ST_CoverageEdges (geom geometry, edgetype integer default 0)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_CoverageEdges'
+	_COST_HIGH;
 -- Availability: 2.3.0
diff --git a/regress/core/coverage.sql b/regress/core/coverage.sql
index 9c456410c..159022e83 100644
--- a/regress/core/coverage.sql
+++ b/regress/core/coverage.sql
@@ -101,3 +101,29 @@ FROM squares
 GROUP BY i, j
 ORDER By i, j;
+CREATE TABLE coverage_edges (id integer, seq integer, geom geometry);
+INSERT INTO coverage_edges VALUES
+(6, 1, 'POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))'),
+(6, 2, 'POLYGON ((10 0, 10 10, 20 10, 20 0, 10 0))');
+SELECT 'coverage edges all' AS test,
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom)))
+FROM coverage_edges WHERE id = 6;
+SELECT 'coverage edges exterior' AS test,
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom), 1))
+SELECT 'coverage edges interior' AS test,
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom), 2))
+SELECT 'coverage edges array' AS test,
+  ST_AsText(ST_CoverageEdges(array_agg(geom)))
+DROP TABLE coverage_edges;
diff --git a/regress/core/coverage_expected b/regress/core/coverage_expected
index 2b456107a..2a0304871 100644
--- a/regress/core/coverage_expected
+++ b/regress/core/coverage_expected
@@ -36,3 +36,7 @@ grid squares|1|2|50000
 grid squares|2|0|50000
 grid squares|2|1|50000
 grid squares|2|2|10000
+coverage edges all|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
+coverage edges exterior|MULTILINESTRING((10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
+coverage edges interior|MULTILINESTRING((10 10,10 0))
+coverage edges array|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
commit 515152e7bf193e6d75831e3794d9d0610d9c7dae
Date:   Wed Apr 1 10:33:30 2026 -0700
    Simplify stringbuffer handling a little
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index 8db842117..9065bdf6f 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -1479,8 +1479,7 @@ ShpLoaderGetSQLHeader(SHPLOADERSTATE *state, char **strheader)
 	/* Copy the string buffer into a new string, destroying the string buffer */
-	ret = (char *)malloc(strlen((char *)stringbuffer_getstring(sb)) + 1);
-	strcpy(ret, (char *)stringbuffer_getstring(sb));
+	ret = strdup(stringbuffer_getstring(sb));
 	stringbuffer_destroy(sb);
 	*strheader = ret;
@@ -1519,8 +1518,7 @@ ShpLoaderGetSQLCopyStatement(SHPLOADERSTATE *state, char **strheader)
 		*strheader = ret;
@@ -1851,14 +1849,13 @@ done_cell:
 	*strrecord = ret;
 	/* If any warnings occurred, set the returned message string and warning status */
-	if (strlen((char *)stringbuffer_getstring(sbwarn)) > 0)
+	if (stringbuffer_getlength(sbwarn) > 0)
 		snprintf(state->message, SHPLOADERMSGLEN, "%s", stringbuffer_getstring(sbwarn));
 		stringbuffer_destroy(sbwarn);
@@ -1943,8 +1940,7 @@ ShpLoaderGetSQLFooter(SHPLOADERSTATE *state, char **strfooter)
 	*strfooter = ret;
Summary of changes:
 NEWS                           |   2 +
 doc/reference_coverage.xml     |  70 ++++++++++++++++++++
 loader/shp2pgsql-core.c        |  14 ++--
 postgis/lwgeom_window.c        | 142 +++++++++++++++++++++++++++++++++++++++++
 postgis/postgis.sql.in         |  14 ++++
 regress/core/coverage.sql      |  26 ++++++++
 regress/core/coverage_expected |   4 ++
 7 files changed, 263 insertions(+), 9 deletions(-)
hooks/post-receive
