[SCM] PostGIS branch master updated. 3.6.0rc2-430-g8cfe6fe6d
Thu Apr 2 12:27:57 PDT 2026
the project "PostGIS".
       via  8cfe6fe6de8906da79047f15d4a340a775aa1f51 (commit)
      from  245ee074f2ca166f296a04ded14ad83c94978c32 (commit)
revisions in full, below.
commit 8cfe6fe6de8906da79047f15d4a340a775aa1f51
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Apr 2 12:27:50 2026 -0700
    Clarification per #6037
diff --git a/doc/xsl-config.xml b/doc/xsl-config.xml
index 77437e98e..fb7904494 100644
--- a/doc/xsl-config.xml
+++ b/doc/xsl-config.xml
@@ -161,9 +161,9 @@
         <para role="tag_overlay_gridsize_arg">
             <para>
                 If the optional <code>gridSize</code> parameter is given (GEOS-3.9.0 or higher required),
-                all result vertices are guaranteed to fall on a grid of the specified
-                size.  For the operation to give predictable results all the input vertices
-                must fall already on the specified grid, see <xref linkend="ST_ReducePrecision"/>.
+                all result vertices are guaranteed to fall on a snap-rounded grid of the specified
+                size.  Note that operations performed on a grid may contain small artifacts
+                produced during grid alignment, see <xref linkend="ST_ReducePrecision"/>.
             </para>
         </para>
     </tags>
Summary of changes:
 doc/xsl-config.xml | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
