[PostGIS] #6066: Pg19 + topology crash on regression test
trac at osgeo.org
Tue Apr 7 10:40:30 PDT 2026
Reporter: pramsey | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.6.2
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by pramsey):
Backtrace at point of crash does not provide much guidance
* thread #1, queue = 'com.apple.main-thread', stop reason = signal SIGABRT
* frame #0: 0x0000000182e545e8 libsystem_kernel.dylib`__pthread_kill + 8
frame #1: 0x0000000182e8f8d8 libsystem_pthread.dylib`pthread_kill +
296
frame #2: 0x0000000182d96790 libsystem_c.dylib`abort + 148
frame #3: 0x000000010460c0f0
postgres`ExceptionalCondition(conditionName=<unavailable>,
fileName=<unavailable>, lineNumber=2192) at assert.c:65:2 [opt]
frame #4: 0x00000001045ffa5c
postgres`RelationDecrementReferenceCount(rel=<unavailable>) at
relcache.c:2192:2 [opt] [inlined]
frame #5: 0x00000001045ffa44
postgres`RelationClose(relation=<unavailable>) at relcache.c:2213:2 [opt]
frame #6: 0x000000010414c8d8
postgres`index_close(relation=<unavailable>, lockmode=0) at
indexam.c:185:2 [opt]
frame #7: 0x000000010459f2dc postgres`ri_FastPathTeardown at
ri_triggers.c:4152:4 [opt] [inlined]
frame #8: 0x000000010459f298
postgres`ri_FastPathEndBatch(arg=<unavailable>) at ri_triggers.c:4130:2
[opt]
frame #9: 0x000000010429b24c postgres`FireAfterTriggerBatchCallbacks
at trigger.c:6861:3 [opt]
frame #10: 0x000000010429b208
postgres`AfterTriggerEndQuery(estate=<unavailable>) at trigger.c:5240:2
[opt]
frame #11: 0x00000001042c1000
postgres`standard_ExecutorFinish(queryDesc=0x0000000c1914a900) at
execMain.c:445:3 [opt]
frame #12: 0x00000001042c0f18
postgres`ExecutorFinish(queryDesc=<unavailable>) at execMain.c:413:3 [opt]
[artificial]
frame #13: 0x00000001044c40dc
postgres`ProcessQuery(plan=0x0000000c190078d0, sourceText="INSERT INTO
t5118f(g) SELECT toTopoGeom('LINESTRING(0 0, 10 0)', 't5118', 1);",
params=0x0000000000000000, queryEnv=0x0000000000000000,
dest=0x0000000c18ca9110, qc=0x000000016bd1d968) at pquery.c:189:2 [opt]
frame #14: 0x00000001044c36b0
postgres`PortalRunMulti(portal=0x0000000c19022100, isTopLevel=true,
setHoldSnapshot=false, dest=0x0000000c18ca9110,
altdest=0x0000000c18ca9110, qc=0x000000016bd1d968) at pquery.c:0 [opt]
frame #15: 0x00000001044c3044
postgres`PortalRun(portal=0x0000000c19022100, count=9223372036854775807,
isTopLevel=<unavailable>, dest=0x0000000c18ca9110,
altdest=0x0000000c18ca9110, qc=0x000000016bd1d968) at pquery.c:783:5 [opt]
frame #16: 0x00000001044c2054
postgres`exec_simple_query(query_string="INSERT INTO t5118f(g) SELECT
toTopoGeom('LINESTRING(0 0, 10 0)', 't5118', 1);") at postgres.c:1288:10
[opt]
frame #17: 0x00000001044bf300
postgres`PostgresMain(dbname=<unavailable>, username=<unavailable>) at
postgres.c:0:24 [opt]
frame #18: 0x00000001044bad5c
postgres`BackendMain(startup_data=<unavailable>,
startup_data_len=<unavailable>) at backend_startup.c:124:2 [opt]
frame #19: 0x0000000104404ba4
postgres`postmaster_child_launch(child_type=<unavailable>, child_slot=1,
startup_data=0x000000016bd1e7f0, startup_data_len=24,
client_sock=0x000000016bd1dd60) at launch_backend.c:265:3 [opt]
frame #20: 0x0000000104408fec
postgres`BackendStartup(client_sock=0x000000016bd1dd60) at
postmaster.c:3627:8 [opt] [inlined]
frame #21: 0x0000000104408f18 postgres`ServerLoop at
postmaster.c:1722:6 [opt]
frame #22: 0x0000000104406f9c
postgres`PostmasterMain(argc=<unavailable>, argv=<unavailable>) at
postmaster.c:1412:11 [opt]
frame #23: 0x000000010431c904 postgres`main(argc=3,
argv=0x00000001065fe870) at main.c:231:4 [opt]
frame #24: 0x0000000182ad3da4 dyld`start + 6992
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6066#comment:1>
