[SCM] PostGIS branch master updated. 3.6.0rc2-434-gacc6afbd9
git at osgeo.org
git at osgeo.org
Wed Apr 8 02:23:04 PDT 2026
the project "PostGIS".
via acc6afbd9212beaf8e2039c7f2369584a6c9ec77 (commit)
from cf42b890bf892d5498af532f1e8804355b44e71d (commit)
revisions in full, below.
commit acc6afbd9212beaf8e2039c7f2369584a6c9ec77
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 29 11:33:51 2026 +0100
FindVertexSegmentPairsBelowDistance function
References #6034
Includes tests and documentation
diff --git a/NEWS b/NEWS
index 19c16e4bc..1a59e317b 100644
--- a/NEWS
+++ b/NEWS
@@ -17,6 +17,7 @@ This version requires GEOS 3.10 or higher
* New Features *
+ - [topology] FindVertexSegmentPairsBelowDistance function (Sandro Santilli)
- ST_CoverageEdges, returns MultiLinestring of distinct shared edges in
polygonal coverage (Paul Ramsey)
- ST_MinimumSpanningTree, window function to calculate MST (Paul Ramsey)
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 4b0aa308a..31fe66eaf 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -3313,6 +3313,47 @@ and is thus usable to build edge ring linking.
</refsection>
</refentry>
+ <refentry xml:id="FindVertexSegmentPairsBelowDistance">
+ <refnamediv>
+ <refname>FindVertexSegmentPairsBelowDistance</refname>
+ <refpurpose>
+ Find pairs of topology vertex/segment that are closer than tolerated distance
+ </refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>setof record <function>FindVertexSegmentPairsBelowDistance</function></funcdef>
+ <paramdef><type>varchar </type> <parameter>atopology</parameter></paramdef>
+ <paramdef><type>float8 </type> <parameter>tolerance</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>
+Returns a relation in which each tuple is a pair of vertex/segment where
+the vertex is NOT an endpoint of the segment but the distance between
+them is below the given tolerance.
+ </para>
+ <!-- use this format if new function -->
+ <para role="availability" conformance="3.7">Availability: 3.7</para>
+ </refsection>
+ <!-- Optionally add a "See Also" section -->
+ <refsection>
+ <title>See Also</title>
+ <para>
+<xref linkend="ValidateTopologyPrecision"/>
+ </para>
+ </refsection>
+ </refentry>
</section>
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 25cae0bfa..3319cf98c 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -130,12 +130,13 @@ topology.sql: \
sql/polygonize.sql.in \
sql/export/gml.sql.in \
sql/export/TopoJSON.sql.in \
- sql/query/getnodebypoint.sql.in \
+ sql/query/FindVertexSegmentPairsBelowDistance.sql.in \
sql/query/getedgebypoint.sql.in \
sql/query/getfacebypoint.sql.in \
- sql/query/GetRingEdges.sql.in \
- sql/query/GetNodeEdges.sql.in \
sql/query/GetFaceContainingPoint.sql.in \
+ sql/query/getnodebypoint.sql.in \
+ sql/query/GetNodeEdges.sql.in \
+ sql/query/GetRingEdges.sql.in \
sql/manage/AddTopoGeometryColumn.sql.in \
sql/manage/CopyTopology.sql.in \
sql/manage/CreateTopology.sql.in \
diff --git a/topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in b/topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in
new file mode 100644
index 000000000..8d5096235
--- /dev/null
+++ b/topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in
@@ -0,0 +1,46 @@
+-- Finds pairs of vertice/segment from a topology that are below a given distance.
+-- The vertex must NOT be part of the segment.
+-- Presence of such proximities represent a missed snap opportunity during topology building
+-- and can sometime be fixed by adding a new node where the vertex is, like:
+-- SELECT topology.TopoGeo_AddPoint('topo', ST_PointN(geom,v.vert))
+-- FROM topo.edge, LATERAL topology.findVertexSegmentPairsBelowDistance('topo', 1e-6) v
+-- WHERE edge_id = v.vert_edge;
+CREATE OR REPLACE FUNCTION topology.findVertexSegmentPairsBelowDistance(toponame varchar, tolerance float8)
+RETURNS TABLE (seg_edge int, segno int, vert_edge int, vertno int, vert_geom geometry)
+AS $BODY$
+DECLARE
+ sql text;
+BEGIN
+ sql := format($$
+ SELECT
+ e1.edge_id seg_edge,
+ s.path[1] segno,
+ e2.edge_id vert_edge,
+ p.path[1] vertno,
+ p.geom vert_geom
+ FROM
+ %1$I.edge e1,
+ %1$I.edge e2,
+ LATERAL ST_DumpSegments(e1.geom) s,
+ LATERAL ST_DumpPoints(e2.geom) p
+ WHERE
+ e1.edge_id != e2.edge_id
+ AND ST_Expand(e1.geom, %2$L) && e2.geom
+ AND ST_Distance(s.geom, p.geom) < %2$L
+ AND NOT (
+ ST_Equals(p.geom, ST_PointN(s.geom, 1))
+ OR
+ ST_Equals(p.geom, ST_PointN(s.geom, 2))
+ toponame,
+ tolerance
+ RETURN QUERY EXECUTE sql;
+END;
+$BODY$
+LANGUAGE 'plpgsql';
diff --git a/topology/test/regress/findvertexsegmentpairsbelowdistance.sql b/topology/test/regress/findvertexsegmentpairsbelowdistance.sql
index 000000000..ac3aac9b0
--- /dev/null
+++ b/topology/test/regress/findvertexsegmentpairsbelowdistance.sql
@@ -0,0 +1,11 @@
+\set VERBOSITY terse
+set client_min_messages to ERROR;
+\i :top_builddir/topology/test/load_topology.sql
+SELECT 't1', 'count', count(*) FROM topology.FindVertexSegmentPairsBelowDistance('city_data', 1);
+SELECT 't2', seg_edge, segno, vert_edge, vertno, ST_AsText(vert_geom)
+FROM topology.FindVertexSegmentPairsBelowDistance('city_data', 1.1)
+ORDER BY 1,2,3,4;
+SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/findvertexsegmentpairsbelowdistance_expected b/topology/test/regress/findvertexsegmentpairsbelowdistance_expected
index 000000000..000575dbb
--- /dev/null
+++ b/topology/test/regress/findvertexsegmentpairsbelowdistance_expected
@@ -0,0 +1,12 @@
+t1|count|0
+t2|1|1|2|5|POINT(17 30)
+t2|1|2|2|5|POINT(17 30)
+t2|1|4|26|1|POINT(4 31)
+t2|1|4|26|4|POINT(4 34)
+t2|1|4|26|5|POINT(4 31)
+t2|1|5|26|1|POINT(4 31)
+t2|1|5|26|2|POINT(7 31)
+t2|1|5|26|5|POINT(4 31)
+t2|2|4|1|2|POINT(16 30)
+t2|2|4|1|3|POINT(16 38)
+t2|2|5|1|2|POINT(16 30)
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index ba1d2e204..3c70599d7 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -99,5 +99,6 @@ TESTS += \
$(top_srcdir)/topology/test/regress/validatetopology.sql \
$(top_srcdir)/topology/test/regress/validatetopology_large.sql \
$(top_srcdir)/topology/test/regress/verifylargeids.sql \
- $(top_srcdir)/topology/test/regress/fix_topogeometry_columns.sql
+ $(top_srcdir)/topology/test/regress/fix_topogeometry_columns.sql \
+ $(top_srcdir)/topology/test/regress/findvertexsegmentpairsbelowdistance.sql
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index c364af34d..e96d9068e 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1379,6 +1379,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
#include "sql/query/getedgebypoint.sql.in"
#include "sql/query/getfacebypoint.sql.in"
#include "sql/query/GetFaceContainingPoint.sql.in"
+#include "sql/query/FindVertexSegmentPairsBelowDistance.sql.in"
-- Populating
#include "sql/populate.sql.in"
Summary of changes:
NEWS | 1 +
doc/extras_topology.xml | 41 +++++++++++++++++++
topology/Makefile.in | 7 ++--
.../FindVertexSegmentPairsBelowDistance.sql.in | 46 ++++++++++++++++++++++
.../findvertexsegmentpairsbelowdistance.sql | 11 ++++++
.../findvertexsegmentpairsbelowdistance_expected | 12 ++++++
topology/test/tests.mk | 3 +-
topology/topology.sql.in | 1 +
8 files changed, 118 insertions(+), 4 deletions(-)
create mode 100644 topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in
create mode 100644 topology/test/regress/findvertexsegmentpairsbelowdistance.sql
create mode 100644 topology/test/regress/findvertexsegmentpairsbelowdistance_expected
hooks/post-receive
