[PostGIS] #6061: segmentation fault when loading geometries
PostGIS trac at osgeo.org
Wed Apr 8 08:45:13 PDT 2026
  Reporter:  maxsynytsky1v  |      Owner:  pramsey
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.6.2
 Component:  postgis        |    Version:  3.6.x
Resolution:                 |   Keywords:
Comment (by maxsynytsky1v):
 Hello.
 As I understand the situation the extraction did not go as expected and
 something broke geometry.
 So we should basically look into this direction.
 It's a bit odd that the data set does not crash at Paul's because as I
 said before it crashes all the clusters I tried at all the times.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6061#comment:14>
