[PostGIS] #6067: MacOS CI failing on topology topogeo_addlinestring, validatetopology
PostGIS trac at osgeo.org
Fri Apr 10 18:16:09 PDT 2026
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.7.0
Component:  topology  |    Version:  master
 Keywords:            |
 GHA MacOS CI appears to be failing on 2 topology tests:
 Run tests: 260
 Failed: 2
 make: *** [check-regress] Error 2
 ---- BEGIN REGRESSION DIFFS (/tmp/pgis_reg) ----
 ---- /tmp/pgis_reg/test_236_diff ----
 --- ./topology/test/regress/topogeo_addlinestring_expected      2026-04-09
 22:05:58
 +++ /tmp/pgis_reg/test_236_out  2026-04-09 22:11:09
 @@ -236,3 +236,4 @@
  t6062.edges|t
  t6064.1|t
  t6064.2|t
 +t6064.check.final|hole not in advertised face|-5|
 ---- /tmp/pgis_reg/test_254_diff ----
 --- ./topology/test/regress/validatetopology_expected   2026-04-09
 22:05:58
 +++ /tmp/pgis_reg/test_254_out  2026-04-09 22:11:12
 @@ -46,4 +46,3 @@
  #5766.2|no bbox|("face has wrong mbr",0,)
  #5766.2|overlapping bbox|("face has wrong mbr",0,)
  #5766.2|disjoint bbox|
 -#6065|invalidities|hole not in advertised face|-4|
 ---- END REGRESSION DIFFS ----
 Stopping `postgresql at 17`... (might take a while)
 ==> Successfully stopped `postgresql at 17` (label:
 homebrew.mxcl.postgresql at 17)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6067>
