[SCM] PostGIS branch stable-3.5 updated. 3.5.5-14-g66fcfd047
git at osgeo.org
git at osgeo.org
Sat Apr 11 15:27:25 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
via 66fcfd047860ee8c675738fe0a40356b7a42ec32 (commit)
from 5c1ed575d82b33355f2ed338e5c41c30e99d2f48 (commit)
revisions in full, below.
commit 66fcfd047860ee8c675738fe0a40356b7a42ec32
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sat Apr 11 15:27:16 2026 -0700
Remove Cirrus-CI
diff --git a/.cirrus.yml b/.cirrus.yml
deleted file mode 100644
index c1eaaf1c9..000000000
--- a/.cirrus.yml
+++ /dev/null
@@ -1,92 +0,0 @@
-task:
- only_if: $CIRRUS_BRANCH =~ 'pull/.*'
- name: FreeBSD
- alias: test-freebsd
- #env:
- #MAKE_FLAGS: -j 8
- install_script:
- - sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
- - ASSUME_ALWAYS_YES=yes pkg bootstrap -f
- - pkg install -y
- autoconf
- automake
- bison
- cunit
- docbook
- gdal
- geos
- gmake
- iconv
- json-c
- libtool
- libxml2
- libxslt
- pcre
- pkgconf
- postgresql13-contrib
- postgresql13-server
- proj
- protobuf-c
- sfcgal
- - projsync --system-directory --source-id us_noaa
- - projsync --system-directory --source-id ch_swisstopo
- patch_script:
- # will be removed
- - find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
- build_script:
- - ./autogen.sh
- - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --with-topology --without-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
- - service postgresql oneinitdb
- - service postgresql onestart
- - su postgres -c "createuser -s `whoami`"
- - gmake || { service postgresql onestop; exit 1;}
- - gmake check RUNTESTFLAGS="-v" || { service postgresql onestop; exit 1;}
- - gmake install || { service postgresql onestop; exit 1;}
- - gmake check RUNTESTFLAGS="-v --extension" || { service postgresql onestop; exit 1;}
- - gmake check RUNTESTFLAGS="-v --extension --dumprestore" || { service postgresql onestop; exit 1;}
- - service postgresql onestop
- freebsd_instance:
- cpu: ${NCPU}
- memory: 24G
- matrix:
- - name: 14.2-RELEASE
- freebsd_instance:
- image_family: freebsd-14-2
-task:
- name: macOS
- alias: test-macos
- test_script:
- - brew update
- - brew install
- autoconf
- automake
- cunit
- docbook
- docbook-xsl
- gdal
- geos
- gpp
- json-c
- libtool
- pcre2
- pkg-config
- postgresql at 14
- proj
- sfcgal
- - ./autogen.sh
- - ./configure --without-gui --without-interrupt-tests --without-topology --without-raster --with-sfcgal --with-address-standardizer --without-protobuf --with-pgconfig=/opt/homebrew/opt/postgresql at 14/bin/pg_config
- - brew services start postgresql at 14
- - postgres -V
- - make -j8 || { brew services stop postgresql at 14; exit 1;}
- - make -j8 check || { brew services stop postgresql at 14; exit 1;}
- - brew services stop postgresql at 14
- matrix:
- macos_instance:
- image: ghcr.io/cirruslabs/macos-ventura-base:latest
- # macos_instance:
- # image: ghcr.io/cirruslabs/macos-monterey-base:latest
Summary of changes:
.cirrus.yml | 92 -------------------------------------------------------------
1 file changed, 92 deletions(-)
delete mode 100644 .cirrus.yml
hooks/post-receive
