[PostGIS] #6067: MacOS CI and winnie failing on topology topogeo_addlinestring, validatetopology
PostGIS trac at osgeo.org
Tue Apr 14 00:30:03 PDT 2026
validatetopology
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.7.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"43af076ad4cf42a4fb1c12cb497425b958246c6f/git" 43af076/git]:
 {{{#!CommitTicketReference repository="git"
 revision="43af076ad4cf42a4fb1c12cb497425b958246c6f"
 Skip dangling parts of ring when computing orientation
 Improves robustness of telling shells apart shells from holes,
 without need for higher precision math in signed area computation.
 References #6067 for the ValidateTopology test ( ref #6065 )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6067#comment:6>
