[SCM] PostGIS branch master updated. 3.6.0rc2-461-ge21fe0083
git at osgeo.org
git at osgeo.org
Wed Apr 15 08:50:38 PDT 2026
the project "PostGIS".
via e21fe0083bd1fdd7477e60162b793870f8b536fc (commit)
via 83ba9c60da7d47e936848eb2a764b23e53c37598 (commit)
via 5e3b36d6ab3cd2c1c1191ac95257332fef0e9e1b (commit)
from 8b5d974cb7f4376c5ebc9936b5ba93aaf826452c (commit)
revisions in full, below.
commit e21fe0083bd1fdd7477e60162b793870f8b536fc
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Apr 15 17:42:00 2026 +0200
Revert "Skip dangling parts of ring when computing orientation"
This reverts commit 43af076ad4cf42a4fb1c12cb497425b958246c6f.
The implementation fails for CCW rings with holes touching the ring
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 9bedb0654..4dff69603 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -468,8 +468,7 @@ BEGIN
SELECT
r.ring_id,
e.seq,
- e.edge signed_edge_id,
- count(e.edge) over (PARTITION BY ring_id, abs(e.edge)) > 1 as dangling
+ e.edge signed_edge_id
FROM all_rings r
LEFT JOIN LATERAL unnest(r.edges) WITH ORDINALITY AS e(edge, seq)
ON TRUE
@@ -483,16 +482,9 @@ BEGIN
ELSE
ST_Reverse(e.geom)
END
+ -- TODO: how to make sure rows are ordered ?
ORDER BY seq
) geom,
- ST_LineMerge( ST_Collect(
- CASE WHEN signed_edge_id > 0 THEN
- e.geom
- ELSE
- ST_Reverse(e.geom)
- END
- ) FILTER ( WHERE NOT r.dangling ) )
- non_dangling_edges_merge,
array_agg(
DISTINCT
@@ -509,7 +501,7 @@ BEGIN
WHERE e.edge_id = abs(r.signed_edge_id)
GROUP BY ring_id
- SELECT ring_id, geom as ring_geom, non_dangling_edges_merge, side_faces, distinct_edges, num_edges
+ SELECT ring_id, geom as ring_geom, side_faces, distinct_edges, num_edges
FROM all_rings_with_ring_geom
LOOP --}{
@@ -556,28 +548,10 @@ BEGIN
IF ST_NPoints(rec.ring_geom) > 3 AND
rec.num_edges != rec.distinct_edges * 2
THEN
- -- TODO: directly build candidate shell polygon from non-dangling portions ?
ring_poly := ST_MakePolygon(rec.ring_geom);
- 1. Make polygon from non-dangling edge merge
- 2. Pick the one with largest area
- 3. Check if CCW
- WITH irings AS (
- SELECT ST_MakePolygon(geom) geom
- FROM ST_Dump(rec.non_dangling_edges_merge)
- -- TODO: report non-closed rings from non-dangling edges as another invalidity
- WHERE ST_StartPoint(geom) = ST_EndPoint(geom)
- largest_iring AS (
- SELECT geom FROM irings
- ORDER BY ST_Area(geom) DESC LIMIT 1
- SELECT ST_IsPolygonCCW(geom) FROM largest_iring
- INTO is_shell;
-#if POSTGIS_TOPOLOGY_DEBUG > 1
- RAISE NOTICE 'Ring % is CCW ? %', rec.ring_id, is_shell;
-#endif
+ IF ST_IsPolygonCCW(ring_poly) THEN
+ is_shell := true;
+ END IF;
END IF;
#ifdef POSTGIS_TOPOLOGY_DEBUG
commit 83ba9c60da7d47e936848eb2a764b23e53c37598
Date: Wed Apr 15 17:39:49 2026 +0200
Revert CCW computation changes in liblwgeom-topo
This reverts 00440ad2900ced28817d18e4908a13bff455588a
but keeps the changes that might make it easier to
improve orientation later.
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 0faec58e5..4abef795c 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -1887,15 +1887,12 @@ static LWPOLY *
_lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num_signed_edge_ids, int *isccw, GBOX *ringbox)
LWT_ELEMID *edge_ids;
- LWT_ELEMID *dangling_edge_ids;
- uint64_t numedges, num_dangling, j, i;
+ uint64_t numedges, j, i;
LWT_ISO_EDGE *ring_edges;
/* Construct a polygon using edges of the ring */
numedges = 0;
- num_dangling = 0;
edge_ids = lwalloc(sizeof(LWT_ELEMID)*num_signed_edge_ids);
- dangling_edge_ids = lwalloc(sizeof(LWT_ELEMID)*num_signed_edge_ids);
for (i=0; i<num_signed_edge_ids; ++i) {
LWT_ELEMID absid = llabs(signed_edge_ids[i]);
int found = 0;
@@ -1903,7 +1900,6 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
for (j=0; j<numedges; ++j) {
if ( edge_ids[j] == absid ) {
found = 1;
- dangling_edge_ids[num_dangling++] = absid;
break;
@@ -1917,13 +1913,11 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
lwfree( edge_ids );
if (i == UINT64_MAX)
- lwfree( dangling_edge_ids );
PGTOPO_BE_ERROR();
return NULL;
else if ( i != numedges )
lwfree( signed_edge_ids );
_lwt_release_edges(ring_edges, i);
lwerror("Unexpected error: %" LWTFMT_ELEMID
@@ -1939,7 +1933,6 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
GBOX edgebox;
if ( LW_SUCCESS != ptarray_calculate_gbox_cartesian(ring_edges[i].geom->points, &edgebox) )
lwerror("Could not calculate bounding box of edge %" LWTFMT_ELEMID, ring_edges[i].edge_id);
return NULL;
@@ -1951,7 +1944,6 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
/* Should now build a polygon with those edges, in the order
* given by GetRingEdges.
- LWCOLLECTION *non_dangling_collection = NULL;
POINTARRAY *full_ring_pa = NULL;
for ( i=0; i<num_signed_edge_ids; ++i )
@@ -1970,7 +1962,6 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
if ( edge == NULL )
_lwt_release_edges(ring_edges, numedges);
lwerror("missing edge that was found in ring edges loop");
return NULL;
@@ -1996,42 +1987,7 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
ptarray_append_ptarray(full_ring_pa, edge->geom->points, 0);
- int found = 0;
- for ( j=0; j<num_dangling; ++j )
- if ( dangling_edge_ids[j] == edge->edge_id )
- found = 1;
- break;
- if ( found )
- LWDEBUGF(2, "Edge %" LWTFMT_ELEMID " is dangling (index %" PRIu64 ")", edge->edge_id, j);
- continue;
- if ( non_dangling_collection == NULL )
- non_dangling_collection = lwcollection_construct_empty(
- COLLECTIONTYPE,
- topo->srid,
- topo->hasZ,
- 0
- POINTARRAY *pa_toadd = ptarray_clone_deep(edge->geom->points);
- if ( eid < 0 )
- ptarray_reverse_in_place(pa_toadd);
- lwcollection_add_lwgeom(
- non_dangling_collection,
- lwline_as_lwgeom(lwline_construct(topo->srid, NULL, pa_toadd))
if ( ! ptarray_is_closed_2d(full_ring_pa) )
@@ -2041,58 +1997,6 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
return NULL;
- if ( non_dangling_collection == NULL ) /* all edges are dangling ! */
- lwnotice("All edges in ring are dangling, will not report as ccw");
- *isccw = 0;
- LWGEOM *merged = lwgeom_linemerge(lwcollection_as_lwgeom(non_dangling_collection));
- lwcollection_free(non_dangling_collection);
- LWDEBUGG(2, merged, "Linemerged non-dangling edges");
- switch (merged->type)
- case LINETYPE:
- LWLINE *line = (LWLINE *)(merged);
- POINTARRAY *pa = line->points;
- *isccw = ptarray_isccw(pa);
- break;
- case MULTILINETYPE:
- double maxarea = 0;
- LWMLINE *mline = (LWMLINE *)(merged);
- /* find the one with the largest area */
- for ( i=0; i<mline->ngeoms; ++i )
- const LWLINE *l = mline->geoms[i];
- const POINTARRAY *pa = l->points;
- double sarea;
- /* skip non-closed rings */
- //if ( ! ptarray_is_closed_2d(pa) ) continue;
- sarea = ptarray_signed_area(pa);
- LWDEBUGF(3, "Signed area of ring %" PRIu64 ": %g", i, sarea);
- if ( fabs(sarea) > fabs(maxarea) ) {
- maxarea = sarea;
- LWDEBUGF(2, "Maxarea: %g", maxarea);
- *isccw = maxarea < 0 ? 1 : 0;
- break;
- default:
- lwerror("%s: Unexpected geometry type from lwgeom_linemerge: %s", __func__, lwtype_name(merged->type));
- return NULL;
POINTARRAY **points = lwalloc(sizeof(POINTARRAY*));
points[0] = full_ring_pa;
@@ -2100,12 +2004,10 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
* which would make it topologically invalid
LWPOLY* shell = lwpoly_construct(0, 0, 1, points);
-#if POSTGIS_DEBUG_LEVEL > 0
- if ( ptarray_isccw(shell->rings[0]) != *isccw )
- LWDEBUGF(1, "CCW disagreement on signed edge id %" LWTFMT_ELEMID, signed_edge_ids[0]);
-#endif
+ /* TODO: skip if all edges were dangling ? */
+ *isccw = ptarray_isccw(shell->rings[0]);
return shell;
commit 5e3b36d6ab3cd2c1c1191ac95257332fef0e9e1b
Date: Wed Apr 15 17:43:42 2026 +0200
Back to long-double
This reverts commit cfb81e6a5bf761b6603a6425e689d82d5f3b046c.
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 5c6796e75..65b72290b 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1083,7 +1083,7 @@ ptarray_signed_area(const POINTARRAY *pa)
const POINT2D *P1;
const POINT2D *P2;
const POINT2D *P3;
- double sum = 0.0;
+ long double sum = 0.0;
double x0, x, y1, y2;
uint32_t i;
Summary of changes:
liblwgeom/ptarray.c | 2 +-
liblwgeom/topo/lwgeom_topo.c | 108 ++--------------------------
topology/sql/manage/ValidateTopology.sql.in | 38 ++--------
3 files changed, 12 insertions(+), 136 deletions(-)
hooks/post-receive
