[PostGIS] #6009: Error of ST_Polygon(raster) function in PostGIS 3.4.3 and 3.5.4
trac at osgeo.org
Tue Apr 28 09:02:51 PDT 2026
Reporter: | Owner: robe
GISuser5432 |
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.5.5
Component: raster | Version: 3.5.x
Resolution: worksforme | Keywords: PostGIS_Raster; Raster;
| ST_Polygon(Raster)
Comment (by GISuser5432):
Sorry for the late return.
this is the result of the full version of PostGIS:
POSTGIS="3.6.0 4c1967d" [EXTENSION] PGSQL="180" GEOS="3.13.1-CAPI-1.19.2"
PROJ="9.6.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.6.0)
GDAL="GDAL 3.10.3, released 2025/04/01" LIBXML="2.9.14" LIBJSON="0.18"
LIBPROTOBUF="1.5.1" WAGYU="0.5.0 (Internal)" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6009#comment:4>
