[SCM] PostGIS branch master updated. 3.6.0rc2-397-g29bd2e10c
Tue Mar 17 13:23:08 PDT 2026
the project "PostGIS".
       via  29bd2e10c284291fd1fd386131eb88ac7b1975eb (commit)
       via  bd08920ac3685cf31bdcb017dd77aa89dbfe07f6 (commit)
      from  e27a0d0ba496937ed6676ac7e84e76b821a6b172 (commit)
revisions in full, below.
commit 29bd2e10c284291fd1fd386131eb88ac7b1975eb
Merge: e27a0d0ba bd08920ac
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 17 13:22:59 2026 -0700
    Merge branch 'a8m-master'
commit bd08920ac3685cf31bdcb017dd77aa89dbfe07f6
Author: Ariel Mashraki <ariel at mashraki.co.il>
Date:   Tue Mar 17 13:41:59 2026 +0200
    Use quote_identifier to build tables in pgis_tablefromflatgeobuf
diff --git a/postgis/lwgeom_in_flatgeobuf.c b/postgis/lwgeom_in_flatgeobuf.c
index 8435cd14e..97ed26b16 100644
--- a/postgis/lwgeom_in_flatgeobuf.c
+++ b/postgis/lwgeom_in_flatgeobuf.c
@@ -75,13 +75,9 @@ Datum pgis_tablefromflatgeobuf(PG_FUNCTION_ARGS)
 	char *schema;
 	text *table_input;
 	char *table;
-	char *format;
-	char *sql;
 	bytea *data;
 	uint16_t i;
-	char **column_defs;
-	size_t column_defs_total_len;
-	char *column_defs_str;
+	StringInfoData sql;
 	if (PG_ARGISNULL(0))
 		PG_RETURN_NULL();
@@ -107,48 +103,34 @@ Datum pgis_tablefromflatgeobuf(PG_FUNCTION_ARGS)
 	flatgeobuf_check_magicbytes(ctx);
 	flatgeobuf_decode_header(ctx->ctx);
-	column_defs = palloc(sizeof(char *) * ctx->ctx->columns_size);
-	column_defs_total_len = 0;
+	initStringInfo(&sql);
+	appendStringInfo(&sql, "create table %s.%s (id int, geom geometry",
+		quote_identifier(schema), quote_identifier(table));
 	POSTGIS_DEBUGF(2, "found %d columns", ctx->ctx->columns_size);
 	for (i = 0; i < ctx->ctx->columns_size; i++) {
 		flatgeobuf_column *column = ctx->ctx->columns[i];
 		const char *name = column->name;
 		uint8_t column_type = column->type;
 		char *pgtype = get_pgtype(column_type);
-		size_t len = strlen(name) + 1 + strlen(pgtype) + 1;
-		column_defs[i] = palloc0(sizeof(char) * len);
-		strcat(column_defs[i], name);
-		strcat(column_defs[i], " ");
-		strcat(column_defs[i], pgtype);
-		column_defs_total_len += len;
-	column_defs_str = palloc0(sizeof(char) * column_defs_total_len + (ctx->ctx->columns_size * 2) + 2 + 1);
-	if (ctx->ctx->columns_size > 0)
-		strcat(column_defs_str, ", ");
-	for (i = 0; i < ctx->ctx->columns_size; i++) {
-		strcat(column_defs_str, column_defs[i]);
-		if (i < ctx->ctx->columns_size - 1)
+		appendStringInfo(&sql, ", %s %s", quote_identifier(name), pgtype);
-	POSTGIS_DEBUGF(2, "column_defs_str %s", column_defs_str);
+	appendStringInfoChar(&sql, ')');
-	format = "create table %s.%s (id int, geom geometry%s)";
-	sql = palloc0(strlen(format) + strlen(schema) + strlen(table) + strlen(column_defs_str) + 1);
-	sprintf(sql, format, schema, table, column_defs_str);
-	POSTGIS_DEBUGF(3, "sql: %s", sql);
+	POSTGIS_DEBUGF(3, "sql: %s", sql.data);
 	if (SPI_connect() != SPI_OK_CONNECT)
 		elog(ERROR, "Failed to connect SPI");
-	if (SPI_execute(sql, false, 0) != SPI_OK_UTILITY)
+	if (SPI_execute(sql.data, false, 0) != SPI_OK_UTILITY)
 		elog(ERROR, "Failed to create table");
 	if (SPI_finish() != SPI_OK_FINISH)
 		elog(ERROR, "Failed to finish SPI");
+	pfree(sql.data);
 	POSTGIS_DEBUG(3, "finished");
 	PG_RETURN_NULL();
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index 10a535bc2..df46eca1e 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -158,6 +158,26 @@ select 'E1', id, bool_1, ST_AsText(geom), bool_2 from ST_FromFlatGeobuf(null::fl
     ) q)
+select '--- Quoted identifiers ---';
+-- Verify that special characters in column names are properly quoted
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_qi', (
+    select ST_AsFlatGeobuf(q) from (
+        select null::geometry, null::text as "col name; with special--chars"
+    ) q
+select 'QI1' where exists (
+    select 1 from information_schema.columns
+    where table_schema = 'public'
+      and table_name = 'flatgeobuf_qi'
+      and column_name = 'col name; with special--chars'
+select 'QI2' where exists (
+    select 1 from information_schema.tables
+    where table_schema = 'public' and table_name = 'flatgeobuf_t1'
 drop table if exists public.flatgeobuf_t1;
 drop table if exists public.flatgeobuf_a1;
 drop table if exists public.flatgeobuf_e1;
+drop table if exists public.flatgeobuf_qi;
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index 61c617de3..c93738ff9 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -24,3 +24,6 @@ ERROR:  mixed geometry type is not supported
 A1|0||t|1|2|3|4|1.2|1.3|2016-06-23 03:44:52.134125+00|hello
 --- Exotic roundtrips ---
 E1|0|t|POINT(1.1 2.1)|f
+--- Quoted identifiers ---
+QI1
+QI2
Summary of changes:
 postgis/lwgeom_in_flatgeobuf.c   | 40 +++++++++++-----------------------------
 regress/core/flatgeobuf.sql      | 20 ++++++++++++++++++++
 regress/core/flatgeobuf_expected |  3 +++
 3 files changed, 34 insertions(+), 29 deletions(-)
hooks/post-receive
