[SCM] PostGIS branch stable-3.3 updated. 3.3.9-8-gd55c69743
git at osgeo.org
git at osgeo.org
Tue Mar 17 16:08:51 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via d55c697432e5023d99b9fa30e2b8e67ecfd23a4e (commit)
from ad3d8e090666cf4822e6735c4288e75111aabcef (commit)
revisions in full, below.
commit d55c697432e5023d99b9fa30e2b8e67ecfd23a4e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Mar 17 16:08:40 2026 -0700
Function qualification improvements to avoid name squatting during upgrades
References #6055
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index d79b0dfc3..bc5607010 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -141,8 +141,10 @@ sql/postgis_for_extension.sql: ../../postgis/postgis.sql.in ../../postgis_revisi
| $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' > $@
sql/postgis_upgrade.sql: sql/postgis_upgrade_for_extension.sql | sql
- $(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
+ cat $< | \
+ $(PERL) -lpe "s/BEGIN\;//g" | \
+ $(PERL) -lpe "s/COMMIT\;//g" | \
+ $(PERL) -lpe "s/^(DROP .*)\;/SELECT \@extschema\@.postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" > $@
sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS) | sql
printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
diff --git a/extensions/postgis_extension_helper.sql.in b/extensions/postgis_extension_helper.sql.in
index b0f73015b..0d642fee8 100644
--- a/extensions/postgis_extension_helper.sql.in
+++ b/extensions/postgis_extension_helper.sql.in
@@ -19,7 +19,9 @@ CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_sta
RETURNS boolean AS
DECLARE
- var_sql_ext text := 'ALTER EXTENSION ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(param_extension) OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) pg_catalog.replace(param_statement, 'IF EXISTS', '');
+ var_sql_ext text := pg_catalog.format('ALTER EXTENSION %s %s',
+ pg_catalog.quote_ident(param_extension),
+ pg_catalog.replace(param_statement, 'IF EXISTS', ''));
var_result boolean := false;
BEGIN
BEGIN
@@ -27,13 +29,13 @@ BEGIN
var_result := true;
EXCEPTION
WHEN OTHERS THEN
- --this is to allow ignoring if the object does not exist in extension
+ -- This is to allow ignoring if the object does not exist in extension
var_result := false;
END;
RETURN var_result;
END;
-LANGUAGE plpgsql VOLATILE;
+LANGUAGE 'plpgsql' VOLATILE;
CREATE FUNCTION postgis_extension_AddToSearchPath(a_schema_name text)
#include "libpgcommon/sql/AddToSearchPath.sql.inc"
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index 756dc80f8..c582d3511 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -13,6 +13,6 @@
-- This drops extension helper functions
-- and should be called at the end of the extension upgrade file
-DROP FUNCTION postgis_extension_drop_if_exists(text, text);
+DROP FUNCTION IF EXISTS postgis_extension_drop_if_exists(text, text);
DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 18ff93746..18e87edb4 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -97,7 +97,10 @@ sql/rtpostgis_for_extension.sql: ../../raster/rt_pg/rtpostgis.sql.in ../../postg
$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
sql/rtpostgis_upgrade.sql: sql/rtpostgis_upgrade_for_extension.sql | sql
+ cat $< | \
#this keeps the @extschema at . in place since extension machinery will replace during install
sql/rtpostgis_upgrade_for_extension.sql: ../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql sql/rtpostgis_upgrade_for_extension.sql.in ../../raster/rt_pg/rtpostgis_drop.sql | sql
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 0bcb61b69..b4d77ef99 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -237,8 +237,10 @@ endif
# and adding the version number
# replace @extschema at . with nothing, this is only used as placeholder for extension install
%.sql: %.sql.in
- $(SQLPP) -I at top_srcdir@/libpgcommon -I at builddir@ $< | grep -v '^#' | \
- $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
+ $(SQLPP) -I at top_srcdir@/libpgcommon -I at builddir@ $< | \
+ grep -v '^#' | \
+ $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" | \
+ $(PERL) -lpe "s'@extschema@\.''g" > $@
#this is redundant but trying to fold in with extension just hangs
postgis_upgrade.sql.in: postgis.sql ../utils/create_upgrade.pl
diff --git a/utils/create_undef.pl b/utils/create_undef.pl
index 4036801dc..1e72bdb50 100755
--- a/utils/create_undef.pl
+++ b/utils/create_undef.pl
@@ -287,10 +287,10 @@ DECLARE
BEGIN
FOR rec IN
SELECT n.nspname, c.relname, a.attname, t.typname
- FROM pg_attribute a
- JOIN pg_class c ON a.attrelid = c.oid
- JOIN pg_namespace n ON c.relnamespace = n.oid
- JOIN pg_type t ON a.atttypid = t.oid
+ FROM pg_catalog.pg_attribute a
+ JOIN pg_catalog.pg_class c ON a.attrelid = c.oid
+ JOIN pg_catalog.pg_namespace n ON c.relnamespace = n.oid
+ JOIN pg_catalog.pg_type t ON a.atttypid = t.oid
WHERE t.typname = '$type'
AND NOT (
-- we exclude complexes defined as types
@@ -398,16 +398,19 @@ DECLARE
var_result text;
var_search_path text;
BEGIN
- SELECT reset_val INTO var_search_path FROM pg_settings WHERE name = 'search_path';
- IF var_search_path NOT LIKE '%' || quote_ident(a_schema_name) || '%' THEN
- var_result := a_schema_name || ' not in database search_path';
+ SELECT reset_val INTO var_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
+ IF NOT var_search_path ~ pg_catalog.quote_ident(a_schema_name) THEN
+ var_result := pg_catalog.concat(a_schema_name, ' not in database search_path');
ELSE
- var_search_path := btrim( regexp_replace(
- replace(var_search_path, a_schema_name, ''), ', *,', ','),
+ var_search_path := pg_catalog.btrim( pg_catalog.regexp_replace(
+ pg_catalog.replace(var_search_path, a_schema_name, ''), ', *,', ','),
RAISE NOTICE 'New search_path: %', var_search_path;
- EXECUTE 'ALTER DATABASE ' || quote_ident(current_database()) || ' SET search_path = ' || var_search_path;
- var_result := a_schema_name || ' has been stripped off database search_path ';
+ EXECUTE pg_catalog.Format(
+ 'ALTER DATABASE %s SET search_path = %s',
+ pg_catalog.quote_ident(current_database()),
+ var_search_path);
+ var_result := pg_catalog.concat(a_schema_name, ' has been stripped off database search_path ');
END IF;
RETURN var_result;
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index d983068d0..f6c702484 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -117,10 +117,18 @@ while(<INPUT>)
#last;
+ elsif (/CREATE SCHEMA topology/)
+ $module = 'postgis_topology';
elsif (/TYPE raster/)
$module = 'postgis_raster';
+ elsif (/FUNCTION postgis_sfcgal_noop/)
+ $module = 'postgis_sfcgal';
elsif (m@('\$libdir/[^']*')@)
$soname = $1;
Summary of changes:
extensions/postgis/Makefile.in | 6 ++++--
extensions/postgis_extension_helper.sql.in | 8 +++++---
extensions/postgis_extension_helper_uninstall.sql | 2 +-
extensions/postgis_raster/Makefile.in | 5 ++++-
utils/create_undef.pl | 25 +++++++++++++----------
utils/create_upgrade.pl | 8 ++++++++
7 files changed, 40 insertions(+), 20 deletions(-)
hooks/post-receive
