[postgis-users] Geotools, Geoserver and PostGIS integration
Paul Ramsey pramsey at refractions.net
Fri Apr 19 08:07:52 PDT 2002
My general thought is that the best web-based OpenGIS system would be to
use WMS for 95% of the rendering, only start hitting WFS for when
feature editing becomes required. So you might want to include Mapserver
in your list of candidate technologies.
P.
Peter Aberline wrote:
> Dear Geotools, Geoserver and PostGIS mailing lists,
> I've posted this message to all three lists, appologies for cross posting.
> I'm currently investigating various options for developing a web based
> mapping system, and geotools, geoserver and postgis seem to have
> the greatest scope for intergration. I would like to ask the groups'
> opinion of using them in an integrated way for a web based mapping
> system.
> My current thinking is around a system that stores spatial and attribute data in
> PostgreSQL using PostGIS, having this data accessed via a Geoserver
> application server, and then using Geotools to render it in a client
> side browser applet.
> This raises some immediate questions:
> * Geotools would probably need new supporting code to handle
>   the WFS request/response interaction. True?
> * Is the GML code in Geotools2 sufficiently developed to be able to render
>   data that has been sourced from a GML based data source?
> * Although WFS doesn't currently specify support for requesting raster datasets,
>   would support for this in all tiers difficult to add? This support would
>   obviously be in an out-of-standard way until WFS matured enough to
>   specify an interaction.
> Obviously any new code developed to add the kind of functionality I needed could
> be contributed back to the projects, if it was considered valuable.
> Does anyone know of any groups that have attempted to use these projects in this way?
> I'ld be keen to hear of anyones experiences, or opinions about the likely success
> of such a project.
> many thanks,
> Peter Aberline.
> The information in this email and in any attachments is confidential and may be privileged.  If you are not the intended recipient, please destroy
> this message, delete any copies held on your systems and notify the sender immediately.  You should not retain, copy or use this email for any
> purpose, nor disclose all or any part of its content to any other person.
> postgis-users mailing list
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
