[postgis-users] odbc arcMap-pg
Cedric BERNIER cedric.bernier at thales-is.com
Fri Apr 26 09:23:29 PDT 2002
Hello everybody,
I'm trying to create a dynamic ODBC connection between a PC WIN 2k with ESRI's
ArcGIS 8.1 and a PC Linux RedHat 7.2 with Postgresql 7.1.3/PostGis
I've used psqlodbc-07_01_0010.zip available on http://odbc.postgresql.org
to install the ODBC driver for postgres on Win 2k,
I have configured the DSN driver to connect with Linux server.
When I run ArcMap, and I add an OLE-DB connection using my ODBC DSN, I can see
the whole content of my database (every tables are represented)
The problem is :
When I choose to add a table with geometry column to my TOC in ArcMap : there is
an error :
[Image]
Although, if the table I add doesn't have any geometry column there is another
error :
[Image]
Is there any limitation in using ODBC links with postgis or postgres , I mean
type mismatch between both application ArcMap - postgres ??
Maybe access right limitations ?
Thank for your help
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020426/ef3cfa74/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020426/ef3cfa74/attachment.jpeg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020426/ef3cfa74/attachment-0001.jpeg>
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020426/ef3cfa74/attachment.vcf>
