[postgis-users] Documentation - XML editors
John Reid jgreid at uow.edu.au
Sun Apr 28 17:02:40 PDT 2002
Agreed.  However until OpenOffice, KWord, AbiWord or .....  have robust,
easy to use and configure support for DocBook, I guess we have to use
what we can find....  The alternative is learn how to use Emacs with the
psgml extension.  I guess for most purposes that is probably overkill -
and I can't see most users going to the trouble of learning it.  From a
support person's point of view,  keep it simple if possible and try to
keep to a consistent set of key bindings ;-)
Bernhard Reiter wrote:
>On Sun, Apr 28, 2002 at 11:42:40AM +1000, John Reid wrote:
>>Just found some more info on editors that support DocBook :-)
>I don't remember the initial info.
>>Is it worth trialling XEE as an editor?  It's not Free Software,
>As for obvious reasons an editor that is proprietory
>cannot be recommended, if you want to further Free Software.
>I wonder what the KDE people use for an editor.
>Additionally I've heard good things about TeXmacs (which is not
>a decendence of emacs), but a visual editor.
john reid                                    e-mail: jgreid at uow.edu.au
technical officer                               building 41, room G02A
school of geosciences                          phone: +61 02 4221 3963
university of wollongong                         fax: +61 02 4221 4250
nsw  2522  australia
uproot your questions from their ground and the dangling roots will be
seen.  more questions!
                                                       -mentat zensufi
apply standard disclaimers as desired...
