[postgis-users] postgis and sgi irix 5.3
    Jiøí Kastner
    indy.j at seznam.cz
    Mon Mar 25 14:06:10 PST 2002
i have problems with compilation  (IRIX 5.3, ANSI C compiler, or gcc)
when i type gmake i'll get this:
cc  -woff 1164,1171,1185,1195,1552  -g  -I. -I../../src/include  -U_NO_XOPEN4 -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/etc"'  -c -o postgis_debug.o postgis_debug.c
cfe: Error: ./postgis.h: 190: Unterminated string or character constant
cfe: Warning 594: postgis_debug.c: 41: #ifdef accepts only one identifier as parameter
cfe: Warning 596: postgis_debug.c: 43: text following #endif violates the ANSI C standard.
gmake: *** [postgis_debug.o] Error 1
in postgis_debug.c is:
#ifdef __CYGWIN__
#include <sys/param.h>
#endif
#define SHOW_DIGS_DOUBLE 15
#define MAX_DIGS_DOUBLE (SHOW_DIGS_DOUBLE + 6 + 1 + 3 +1)
#define DEBUG_GIST
#define DEBUG_GIST2
OR:
postgis_debug.c: In function `decode_wkb_collection':
postgis_debug.c:214: `BYTE_ORDER' undeclared (first use in this function)
postgis_debug.c:214: (Each undeclared identifier is reported only once
postgis_debug.c:214: for each function it appears in.)
postgis_debug.c:214: `LITTLE_ENDIAN' undeclared (first use in this function)
postgis_debug.c: In function `decode_wkb':
postgis_debug.c:283: `BYTE_ORDER' undeclared (first use in this function)
postgis_debug.c:283: `LITTLE_ENDIAN' undeclared (first use in this function)
