[postgis-users] Re: MySQL 4.1 GIS Functionality
Paul DuBois
paul at kitebird.com
Tue Aug 5 09:49:23 PDT 2003
Sorry for this delayed response to a message that was posted some
weeks ago. I only recently became aware of the original message,
because I subscribed after June 19, 2003 when it was posted.
Thanks to Paul Ramsey (and Dave Blasby?) for taking a look at
MySQL's GIS support and giving it a test. I have a couple of pieces
of information in reply from Alexey Botchkov, one of the MySQL AB
developers. Replies to him can be sent through me, either at
paul at kitebird.com or paul at mysql.com. Or you can write to Alexey
directly at hf at mysql.com, but please also cc: me so that I can
follow the discussion. Thanks.
The doubly quoted sections below are by Paul Ramsey, the singly quoted
sections are by Alexey. I have also added a few comments of my own.
>> * Spatial data (geometry) only works with the MyISAM table type.
>We need a kind of RTree indexes implemented in InnoDB to make spatial
>extentions working with transactional bases.
To confirm: Spatial column types indeed currently are supported only
for MyISAM tables.
>> * Trying to create create an InnoDB table with a geometry column, will
>> crash the server and muddle the system tables.
>Yes, we should prevent creating spatial fields in InnoDB now.
This means that you now will get an error if you try to create a
table other than a MyISAM table that includes spatial columns.
For example:
mysql> CREATE TABLE t (g GEOMETRY) TYPE = INNODB;
ERROR 1178 (42000): The storage engine for the table doesn't support GEOMETRY
Both Alexey and I were surprised that Paul experienced a server crash
and muddled system tables. (By "system tables", I assume what was meant
was the grant tables in the mysql database? If not, can you clarify?)
Alexey suspects this was a problem in an earlier version that has been
corrected.
By the way, what was the test system (or systems)?
>> * The MySQL spatial index is not null-safe. Marking the geometry column
>> as "NOT NULL" is required in order to build a MySQL spatial index. The
>> PostGIS spatial index is null safe.
>We're working on this.
To confirm: Spatial columns included in an index must indeed currently
be declared NOT NULL.
>> * We did three test queries to compare the retrieval times on the
>> spatial index: first with a very small bounding box (enclosing 6
>> records), then with a medium box (70K records), then with a huge box
>> (all 200K records).
>When we tried PostGIS against MySQL we got almost equal productivity on
>selects.
>Can i get data you used for these tests?
>> * MySQL spatial supports only 2D geometries.
>We don't have any plans here.
>> * This String/Geometry duality causes the structure of the code to
>> fairly complex. Geometry processing is done mostly in the String
>> handling section of the code base, but also appears in the SQL parser
>> and other scattered parts of the system. We have no idea why they did
>> this, but it sure makes it difficult to follow the logic in the system.
>We couldn't find a better way to put OpenGIS recomendation in MySQL parser.
>Probably there's better solution. We plan to review this part of the code.
>> * We did not look too deeply at the indexing source code, but it in the
>> myisam/ directory, so we assume it is either built inside a myisam
>> structure or is only useable on myisam tables. Either way, transactions
>> and ACID guarantees will be lacking.
>I don't know the InnoDB code, but I suspect that implementation of
>spatial indexes will differ significally here.
>Regards.
>HF
Some additional comments in reply to other points in Paul's original
message:
>* MySQL stores the spatial data internally as WKB. Retrieving WKB should
>be very fast, but we were not able to test that directly at this time.
The internal structure is closer to WKB + SRID.
>* The MySQL code contains an assumption in the WKB handling that all WBK
>will be little endian. If you run MySQL spatial on a big endian machine
>(Sparc, PowerPC, PA-RISC) you will find things go amiss when you try to
>send WKB to little endian machines (x86), because your big endian
>machine will be creating invalid data (big endian data incorrectly
>flagged as little endian). Hopefully MySQL will fix this soon.
I'm not sure about this. For example, I've directly copied the
files corresponding to tables containing GIS data from Mac OS X
(big-endian) to Red Hat on Intel (little-endian) and been able to
use them with no problem.
If you discovered a problem in this area, I'm sure the developers
would like to see a repeatable test case so that they can address it.
Thanks.
>* Spatial types are stored as WKB Strings in the MySQL database. They
>seem to have allocated a header on these for the SRID, but access to
>this is unimplemented.
I'm unclear what this means. There is an SRID() function for obtaining
the SRID of a geometry value.
>* 4.1 is still just the "testing" release, but we did find it
>surprisingly brittle. Our attempts to create geometries in InnoDB
>tables failed (fine) but created inconsistent system tables in the
>process (not fine). Spatial indexes seemed impossible to create, until
>we realized the creation command seemed be sensitive to the case of the
>referenced table name.
This is most likely a manifestation of MySQL's general behavior that
table (and database) names are case sensitive on machines with case
sensitive filesystems, unless you run the server with the
--lower-case-table-names=1 option.
>* The MySQL developers made a real effort to follow the OpenGIS
>specification, sometimes to their own detriment. There are four
>different MBR comparison functions, with the correct (and confusing)
>OpenGIS-style function names (MBRContains, MBRTouches, MBRIntersects,
>MBRWithin). Intersects and Touches are subtly different things.
Can you amplify more on what "to their own detriment" means?
That it would have been better to implement these as operators
rather than as functions?
