[postgis-users] integrated EMPTY GeometryCollections to postgis (in CVS)
Carl Anderson carl.anderson at vadose.org
Thu Aug 7 17:51:31 PDT 2003
Dave,
I think you ran on a bit with the *_gc stuff
in CVS
(postgis_sql_common.sql.in)
setSRID(geometry,int)  calls
    CREATE FUNCTION setSRID(geometry,int4)
         RETURNS geometry
         AS '@MODULE_FILENAME@','geometry_from_text_gc'
         LANGUAGE 'C' WITH (isstrict,iscachable);
should'nt that call 'geometry_from_text' instead??
so that
setSRID('BOX3D .....', ..)
as called by UMN mapserver works.
C.
