[postgis-users] integrated EMPTY GeometryCollections to postgis (in CVS)
David Blasby
dblasby at refractions.net
Fri Aug 8 09:17:08 PDT 2003
> I hadn't heard of this before. Where would I find this documented? (which
> simple features spec) Is there anything special about empty WKB
> collections?
> I would like to incorporate proper support for this in OGR.
This isnt a very big change.
Before postgis didnt allow for empty geometries. This was mostly just
because they're hard to index because they dont have a bounding box!
I've fixed this, but I had to change some functions to be aware of these
empty geometries. All the in/out functions (WKT->postgis geometry,
postgis geometry->WKT, WKB->postgis, postgis->WKB, postgis->geos,
geos->postgis) had to be changed, plus several support functions.
You'll see reference to empty geometries in the OGC SF SQL spec. Also
the multi* and geometrycollection description say its a set of 0 or more
geometrys.
The only thing we dont support are funny geometries like:
LINESTRING(EMPTY) {use MULTILINESTRING(EMPTY) instead}
POINT(EMPTY) {use MULTIPOINT(EMPTY) instead}
POLYGON((EMPTY)) {use MULTIPOLYGON(EMPTY) instead}
Postgis still doesnt support GEOMETRYCOLLECTIONS with other geometry
collections (or multi*) in them. They get converted like this:
GEOMETRYCOLLECTION( LINSTRING(0 0, 1 1), MULTIPOINT(0 0, 1 1)) -->
GEOMETRYCOLLECTION( LINSTRING(0 0, 1 1), POINT(0 0),POINT(1 1) )
dave
ps. did you see I changed WKB's 3d flag to 0x8000000?
