[postgis-users] geometryN() pointN() interiorRingN() - 0 or 1 based indexing
David Blasby
dblasby at refractions.net
Fri Aug 8 09:56:05 PDT 2003
PostGIS (and I believe JTS and GEOS) all use 0-based numbering for these
functions. So, pointN(<linestring>, 0) is the 1st point, and
pointN(<linestring>, 1) is the second point.
s2.1.6.1 of the spec says:
PointN(N:Integer):Point—Returns the specified point N in this Linestring.
The documentation of the rest of the ...N() functions are equally useless.
I noticed in the example SF SQL conformance test that they show the
results of pointN(<linestring>,1) being the 1st point in the linestring
(not the 2nd).
I would like to change postgis so its conformant on this issue (1=first
point), but I wanted to get some feedback first. Is this going to cause
anyone hardship?
dave
