[postgis-users] itemnquery limitation
David Blasby
dblasby at refractions.net
Fri Aug 8 10:40:20 PDT 2003
Zamil Murji wrote:
> WHAT?? That can't be good. What do you think I did wrong. For a smaller subset of the data (ie. a select that that worked) this is what I got:
No - thats not good.
> Exactly what I expected to get back...What have i done wrong? The query seems to fail on larger record sets. What can I do to trace this error?
Its difficult to debug this. But if you pg_dump your table and send it
to me I can run it here and fix the problem.
dave
