[postgis-users] itemnquery limitation
David Blasby
dblasby at refractions.net
Mon Aug 11 09:26:55 PDT 2003
Tom Melhuish wrote:
> Dave,
> Sorry, I was out on Friday. Attached is the PG_DUMP of my nodes table
> (nodescomb_2003.sql) along with the sql statements (NodeTbl_2003.sql) that I
> actually used to create the table. I'm using perl to create the html file
> that calls mapserv, so I copied the source (test.html) along with the map
> file (WCms.map) to help you recreate the problem at your location. Let me
> know if you need anything else.
Thanks - did you check to see if you had the correct version of
libpq.dll (and no others) on your system?
Are you running on linux or windows?
dave
