[postgis-users] MAXFEATURES
Zamil Murji
Zamil.Murji at divestco.com
Tue Aug 12 12:37:22 PDT 2003
Hi David,
If I limit it to 40 records, everything works great, however, I only get the first 40 records. Not what I wanted. My query could return upwards of 200 rows.
I'm using the exact same version as you...hmm. I wonder what else could be going wrong.
So will that patch be in CVS soon? I want to work with the CVS version so I don't miss a step.
Zamil
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: Tuesday, August 12, 2003 1:32 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] MAXFEATURES
Zamil Murji wrote:
> What version of postgresql are you using? What version of postgis? My query still hangs at 41 records, so i want to upgrade to your version. How can i check what version of postgresql I have installed?
What happens if you use your patch and limit it to 40 records?
dblasby=# select version();
version
PostgreSQL 7.3.3 on i686-pc-linux-gnu, compiled by GCC 2.96
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
