[postgis-users] Help please
Zamil Murji Zamil.Murji at divestco.com
Tue Aug 12 18:41:29 PDT 2003
yup...i am using the version inside my cgi-bin.
This explains why David wouldn't hang when running it commandline. Maybe it is web specfic.
Zamil
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Tuesday, August 12, 2003 7:39 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Help please
You're sure you are using the same executable both times?
Zamil Murji wrote:
> If I run the following in my web browser, I freeze up/hang after 5 entries:
> http://10.0.50.30/cgi-bin/mapserv?mode=nquery&map=/mapfiles/idc-query.map&imgext=-98.86166+28.00098+-98.73630+28.10481&mapsize=524+434&imgbox=122+199+307+365
> If I run the following on my unix box, everything works just fine:
> ./mapserv "QUERY_STRING=mode=nquery&map=/mapfiles/idc-query.map&imgext=-98.86166+28.00098+-98.73630+28.10481&mapsize=524+434&imgbox=122+199+307+365" > hello.txt
> hello.txt has all the shapes in it. So it doesn't work from my web page, but works commandline. huh?
> don't know hwere to go from here. any suggestions?
> Zamil
> From: David Blasby [mailto:dblasby at refractions.net]
> Sent: Tuesday, August 12, 2003 6:02 PM
> To: PostGIS Users Discussion; morissette at dmsolutions.ca
> Daniel,
> I've noticed that msPOSTGISLayerClose() is being called once more than
> msPOSTGISLayerOpen()::
> msPOSTGISLayerOpen called
> msPOSTGISLayerWhichShapes called
> msPOSTGISLayerClose datastatement: the_geom from nodescomb_2003
> in msPOSTGISLayerGetItems  (find column names)
> I verified the last close - it is definately closing an already closed
> layer.  This is during an itemnquery.
> Also, this looks like an awful lot of work for an itemnquery - whats it
> really supposed to be doing?  It calls msPOSTGISLayerGetShape() twice
> for each of the 'itemn' results.  Once without layer->items set, and
> once with it set.  You'll notice that the shapes are retrieved from the
> database a total of 4 times (twice by rectange and twice by ID)!
> dave
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
