[postgis-users] Install problems postgis.0.8 with geos
Düster Horst
Horst.Duester at bd.so.ch
Thu Aug 21 08:40:40 PDT 2003
I did install postgres7.2.4 with option LDFLAGS=-lstdc++, geos-cvs.tar from
today and postgis-cvs.tar from today.
Postgres compiled correct and is running.
GEOS compiled correct and is installed.
PostGIS compiled with warning: postgis_inout.c:1435: warning: implicit
declaration of function `PG_NARGS'
after installation of Postgis and plpgsql I'm not able to setup a PostGIS
database. After creation of every PostGIS function the following error
message.
Load of file /usr/local/pgsql/lib/libpostgis.so.0.8 failed: dlopen:
/usr/local/pgsql/lib/libpostgis.so.0.8: symbol "PG_NARGS" unresolved
I tried to install postgis without GEOS (USE_GEOS=0) but with the same
result.
The installation of postgis 0.7.5 works without any problem.
Any hint????
With best regards
Horst
