AW: [postgis-users] Install problems postgis.0.8 with geos
Düster Horst Horst.Duester at bd.so.ch
Fri Aug 22 00:55:15 PDT 2003
David
Thank you for your response. Now installation works. But I'm faced with an
other problem. All spatial functions p.e
select convexhull(wkb_geometry) from geo_gemeinden;
responses with
ERROR:  floating point exception! The last floating point operation either
exceeded legal ranges or was a divide by zero
FYI the SRID of the layer geo_gemeinden is -1. Could it be the reason of
this error???
GEOS 21.08.2003
POSTGIS 22.08.2003
With best regards
Horst
Mit freundlichen Grüssen
Dr. Horst Düster
Leiter
Abteilung SO!GIS Koordination
Rötihof
4500 Solothurn
Tel.: 032 627 25 32
Fax: 032 627 22 14
horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
www.sogis.so.ch <http://www.sogis.so.ch>
-----Ursprüngliche Nachricht-----
Von: David Blasby [mailto:dblasby at refractions.net]
Gesendet am: Donnerstag, 21. August 2003 17:22
An: PostGIS Users Discussion
Betreff: Re: [postgis-users] Install problems postgis.0.8 with geos
Düster Horst wrote:
> Load of file /usr/local/pgsql/lib/libpostgis.so.0.8 failed: dlopen:
> /usr/local/pgsql/lib/libpostgis.so.0.8: symbol "PG_NARGS" unresolved
Oops - my fault.  I didnt commit strk's changes.
I've commited them now - so update and everything should be good for you.
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
