[postgis-users] Installation problem postgis
Venu Kanaparthy
madhavsinghk at yahoo.com
Sun Aug 24 01:36:42 PDT 2003
I got the following error trying to install posgis,
can anyone give some pointers.
cd /usr/share/postgresql-7.3.4/contrib/postgis-0.7.5
$ make
gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations -g -I. -I../../src/in
clude -DFRONTEND -DSYSCONFDIR='"/etc/postgresql"' -DUSE_VERSION=73 -c -o postg
is_debug.o postgis_debug.c
is_ops.o postgis_ops.c
is_fn.o postgis_fn.c
is_inout.o postgis_inout.c
is_proj.o postgis_proj.c
is_chip.o postgis_chip.c
is_transform.o postgis_transform.c
postgis_transform.c: In function `transform_geom':
postgis_transform.c:437: warning: control reaches end of non-void function
is_gist_72.o postgis_gist_72.c
is_estimate.o postgis_estimate.c
dlltool --export-all --output-def postgis.def postgis_debug.o postgis_ops.o post
gis_fn.o postgis_inout.o postgis_proj.o postgis_chip.o postgis_transform.o postg
is_gist_72.o postgis_estimate.o
dllwrap -o postgis.dll --dllname postgis.dll --def postgis.def postgis_debug.o p
ostgis_ops.o postgis_fn.o postgis_inout.o postgis_proj.o postgis_chip.o postgis_
transform.o postgis_gist_72.o postgis_estimate.o ../../src/utils/dllinit.o -L/us
r/local/lib -L/usr/local/lib -L../../src/backend -lpostgres
fu000001.o(.idata$3+0xc): undefined reference to `_libpostgres_a_iname'
nmth000000.o(.idata$4+0x0): undefined reference to `__nm__cpu_index_tuple_cost'
Info: resolving _cpu_index_tuple_cost by linking to __imp__cpu_index_tuple_cost
(auto-import)
collect2: ld returned 1 exit status
dllwrap: gcc exited with status 1
make: *** [libpostgis.a] Error 1
Thanks in advance,
Venu
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030824/9f472175/attachment.html>
