[postgis-users] How to generalize or simplify a Polygon
Chris Faulkner chrisf at oramap.com
Thu Aug 28 09:37:27 PDT 2003
Good luck with your search for an implementation of a line generalization. I
am using Java Topology Suite (http://www.vividsolutions.com/jts/jtshome.htm)
with postgis and was hoping that they would offer something similar.
Unfortunately, it doesn't.
I would have thought that your expectation that the resulting polygon should
cover at least as much area as the original is unrealistic. It you
generalise a line around a polygon, you change it's shape and if you change
shape, you change area. Full stop.
Chris
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Matt
Lynch
Sent: 28 August 2003 16:45
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] How to generalize or simplify a Polygon
I have an application where I will be accepting a shape file (polygon)
to define a region of permitted access for a user which will be imported
to postgis.  That shape file has the potential to have many points if
the region defined has a border like a river or lake.  Are there any
functions or tools available that would take a polygon shape and reduce
or generalize the number of points in the polygon?  The resulting
polygon must cover at least as much area as the original.
Thanks,
Matt
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.507 / Virus Database: 304 - Release Date: 8/4/2003
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
