[postgis-users] Mapserv Issues
David Blasby
dblasby at refractions.net
Mon May 17 10:26:41 PDT 2004
Zamil Murji wrote:
> Thanks Dave
> Either way produces the same error
> msPOSTGISLayerGetItems(): Query error. Error executing POSTGIS SQL statement (in msPOSTGISLayerGetItems): SELECT * FROM (select
> oid, to_date(main_well1.spud_date, 'YYYY-MM-DD') as pretty_spud_date, to_date(main_well1.rig_release_date, 'YYYY-MM-DD') as prett
> y_rig_release_date, * from main_well1) as new_table false LIMIT 0
> -ERROR: parser: parse error at or near "false" at character 204
> sprintf(sql,"SELECT * FROM (%s) WHERE false LIMIT 0",table_name);
> or
> sprintf(sql,"SELECT * FROM %s WHERE false LIMIT 0",table_name);
Did you stick the "WHERE" part in the line - it isnt in the SQL query.
dave
