[postgis-users] where intersects(the_geom,foobox) = woes
Fred McDavid
frm at bitdaddy.com
Wed Sep 1 11:51:11 PDT 2004
Dohh! Thank you.
--Fred
On Wednesday 01 September 2004 11:50 am, Paul Ramsey wrote:
> POLYGON((
> 671357.696781 4226841.65215,
> 671357.696781 4226841.65215))
> Your polygon is invalid... it has no dimension to it... the && operator
> does not care, it just does min/max tests using whatever coordinates
> touch it. But intersects() definitely does care. Give you box some
> width and height, you will find that things work better.
> On Tuesday, August 31, 2004, at 10:03 PM, Fred McDavid wrote:
> > Hi,
> > I'm having trouble with the intersects (also tried overlaps, crosses
> > and
> > contains with the same result). Using the && operator, I get two rows
> > returned, but when I add an "and intersects(...)" clause, I get no
> > results.
> > The following works as expected:
> > select gid,the_geom from staunton_parcels where the_geom &&
> > GeometryFromText('POLYGON((671357.696781 4226841.65215,671357.696781
> > 4226841.65215,671357.696781 4226841.65215,671357.696781
> > 4226841.65215))',-1);
> > but this does not:
> > and intersects(the_geom,GeometryFromText('POLYGON((671357.696781
> > 4226841.65215,671357.696781 4226841.65215))',-1));
> > Am I missing something or is there a more appropriate way of finding
> > the
> > shapes that "intersect" (I may not fully understand this from a gis
> > perspective...what I'm trying to do amounts to a select-by-rectangle
> > feature
> > on all of the mapping applications I've seen) a shape/poly/line?
> > Regards,
> > Fred McDavid
> > ------------ VERSION INFO -----------------
> > fred at vespucci:~$ dpkg -l | egrep -e "gis|postgres"
> > ii libpostgis 0.8.2-1 spatial extensions for postgresql
> > (library)
> > ii postgis 0.8.2-1 spatial extensions for postgresql
> > ii postgis-bin 0.8.2-1 spatial extensions for postgresql
> > (binaries)
> > ii postgresql 7.4.2-4 Object-relational SQL database,
> > descended fr
> > ii postgresql-cli 7.4.2-4 Front-end programs for PostgreSQL
> > ii postgresql-con 7.4.2-4 Additional facilities for PostgreSQL
> > Fred R. McDavid, III
> > 540-248-0838
> > frm at bitdaddy.com
> > BitDaddy Systems, Inc
> > * Complex System Design, Management, and Hosting
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
540-248-0838
frm at bitdaddy.com
