[postgis-users] out of memory when using simplify
John Cole
john.cole at uai.com
Wed Sep 29 08:15:26 PDT 2004
Hello,
I'm trying to do some processing on a roads layer and simplify it for
rendering speed. In ArcInfo, I would use a dissolve on the hwy_num field
and then simplify it to 500 meters.
From the documentation, PostGIS seems like it can do the same thing, first
selecting into a new table using either the GeomUnion or Collect aggregates
and then again using simplify, however using simplify returns the following
error:
ERROR: out of memory
DETAIL: Failed on request of size 4172712.
here is my query:
select hwy_num, simplify(the_geom, 500) as the_geom from ra1bb
where ra1bb is created from:
select hwy_num, geomunion(the_geom) as the_geom into ra1bb from ra1
group by hwy_num
Another question: what is the difference between collect and geomunion
(besides speed)? Which one would better approximate an ArcInfo dissolve
function?
Thanks,
John Cole
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040929/ab223938/attachment.html>
